メインコンテンツにスキップ
1999-2004 Nissan Xterra Headlight Bulbs Replacement
必要な工具と部品
  1. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement, Headlight Bulb: 手順 1、 2の画像 1 1999-2004 Nissan Xterra  Headlight Bulbs Replacement, Headlight Bulb: 手順 1、 2の画像 2
    • Reach under the driver's cabin panel and pull on the hood release.
    • It is about 10 inches from the left edge of the panel.
    • After pulling the release, you will hear a "pop" sound indicating that the hood is open.
  2. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 2、 1の画像 1
    • Pull up the hood release latch.
    • It is located about 6 inches to the right, from the center of the hood.
  3. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 3、 2の画像 1 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 3、 2の画像 2
    • Insert the hood support.
    • The support is located about 4 inches behind the hood latch opener.
  4. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 4、 3の画像 1 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 4、 3の画像 2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 4、 3の画像 3
    • Squeeze and disconnect the electrical component from the rear end of the bulb.
    • The squeezing should be done by placing one finger above and another below the component.
  5. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 5、 3の画像 1 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 5、 3の画像 2 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 5、 3の画像 3
    • Turn the retaining ring counterclockwise until it is free from the headlight.
    • Remove this component and set it aside.
  6. 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 6、 2の画像 1 1999-2004 Nissan Xterra  Headlight Bulbs Replacement: 手順 6、 2の画像 2
    • Carefully remove the headlight bulb.
    • The headlight bulb is immediately behind the retaining ring removed in Step 5.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
終わりに
To replace the headlight bulb, follow these instructions in reverse order with the new halogen bulb. When inserting the new bulb, ensure that the plastic outcropping is facing up to ensure that the bulb stays secure.
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Lance Cross
メンバー登録日: 09/17/19
163 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 38
今までの合計 5,483
