メインコンテンツにスキップ
1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement
必要な工具と部品
ビデオの概要
  1. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement, Brake Pad: 手順 1、 1の画像 1
    • With the transmission in park, firmly set the parking brake
    • source.
  2. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 2、 2の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 2、 2の画像 2
    • Open the hood and locate the brake fluid reservoir at the back of the engine compartment
    • source.
  3. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 3、 1の画像 1
    • Open but do not remove the cap
    • source
    • This allows the brake fluid to be forced back into the reservoir while compressing the brake caliper piston during the removal process
    • source.
  4. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 4、 1の画像 1
    • If the brake fluid level is at or near the full mark, make room in the reservoir by drawing off enough fluid with a turkey baster to bring the level down near the add mark
    • source.
  5. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 5、 1の画像 1
    • Before jacking the wheel and tire assembly off the ground, loosen the lug nuts about one quarter turn each
    • source.
  6. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 6、 1の画像 1
    • Carefully jack one side of the axle high enough to get the respective tire an inch or two off the ground
    • source.
  7. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 7、 1の画像 1
    • Position your jack stand under the axle tube between the lower control arm mount and the sway bar bushing bracket
    • source.
  8. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 8、 1の画像 1
    • Carefully lower the axle onto the jack stand, ensuring it will be stable and secure
    • source.
  9. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 9、 2の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 9、 2の画像 2
    • Remove the lug nuts and the wheel and tire, setting them out of the way
    • source
    • Be sure to put the five lug nuts in a place they won't accidentally be kicked across the floor
    • source.
  10. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 10、 1の画像 1
    • Before removing the old brake pads, spread newspaper below the work area
    • source.
  11. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 11、 2の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 11、 2の画像 2
    • Using a brake cleaning solvent of your choice, remove all brake dust residue from the work area
    • source
    • Wear safety glasses during this step
    • source.
  12. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 12、 1の画像 1
    • After the solvent has flashed off, remove the two protective caps that cover the brake caliper mounting bolts
    • source.
  13. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 13、 2の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 13、 2の画像 2
    • To remove the brake pads, first compress the brake caliper piston back into the brake caliper using a large C-clamp
    • source
    • Place the top of the clamp on the far side of the brake caliper and the bottom part of the clamp on the backing of the brake pad nearest you
    • source.
  14. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 14、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 14、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 14、 3の画像 3
    • As you tighten the C-clamp, the brake caliper piston will be forced back into the brake caliper, allowing clearance to remove the brake caliper assembly off of the caliper mounting bracket
    • source.
  15. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 15、 1の画像 1
    • Check the fluid reservoir underneath the hood so that you don't overflow the fluid reservoir with brake fluid and spill it into your engine compartment
    • source.
  16. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 16、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 16、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 16、 3の画像 3
    • Using a 7mm Allen attachment, remove the upper and lower caliper mounting bolts
    • source.
  17. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 17、 1の画像 1
    • Gently pry the little clips off with a screwdriver
    • source.
  18. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 18、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 18、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 18、 3の画像 3
    • Remove the caliper, inner brake pad, and outer brake pad
    • source
    • Do not let the caliper hang by the brake hose
    • source; instead, place it on the control arm after removing the inner brake pad
    • source.
  19. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 19、 1の画像 1
    • The outer brake pad just slides off through the grooves in the caliper mounting bracket
    • source.
  20. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 20、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 20、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 20、 3の画像 3
    • Clean the brake caliper and caliper mounting bracket of any braking residue
    • source.
  21. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 21、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 21、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 21、 3の画像 3
    • Apply anti-squeal compound to the backing of the new brake pads
    • source.
  22. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 22、 1の画像 1
    • Reinstall the new brake pad in the caliper
    • source.
  23. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 23、 1の画像 1
    • Apply a small amount of anti-squeal compound to the caliper mounting brackets
    • source.
  24. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 24、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 24、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 24、 3の画像 3
    • Install the new outer brake pad by sliding it into the respective grooves of the caliper mounting bracket
    • source.
  25. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 25、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 25、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 25、 3の画像 3
    • If the brake piston is not retracted enough to allow for the additional width of the new thicker brake pads, installing the brake caliper can be more difficult
    • source.
  26. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 26、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 26、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 26、 3の画像 3
    • Clean the caliper mounting bolts off with solvent and paper towels
    • source.
  27. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 27、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 27、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 27、 3の画像 3
    • Apply a thin coat of high-temperature disc brake grease to the smooth sliding surface of the bolts before reinstallation
    • source.
  28. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 28、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 28、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 28、 3の画像 3
    • Tighten the bolts to between 21 and 30 foot-pounds using a torque wrench
    • source.
  29. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 29、 1の画像 1
  30. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 30、 1の画像 1
    • Reinstall the wheel and tire assembly
    • source.
  31. 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 31、 3の画像 1 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 31、 3の画像 2 1999-2004 Jeep Grand Cherokee WJ Brake Pad Replacement: 手順 31、 3の画像 3
    • Tighten all five lug nuts in a star pattern, torquing to 95 foot-pounds with a torque wrench
    • source.
    • After lowering the vehicle to the ground, re-torque the lug nuts to 95 foot-pounds.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
eCuration
メンバー登録日: 05/19/17
376,693 ポイント
234のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,410のガイドは作成済み
2 件のコメント
So there is the option for the teves or akebono on these jeeps…what I am assuming is the teves have the wire that has to be detached as shown in this video, correct? I’d like to verify before I purchase the wrong parts and have to return the parts. Any help that you could provide to me would be great, thanks.
harrye04 - 返信
Very good video overall. May I suggest #1) use a breaker bar to loosen and remove lug nuts, always pushing DOWN on bar instead of pulling UP . Pulling UP compresses your spine and can aggravate or injure folks, especially us older grease monkeys. #2) we usually do not replace brake pads without regrinding brake rotors first, but overall a VERY good video. Oh and nitrile gloves are a great way to protect hands from solvents ect. Thanks!! T.N.
anewmantnt - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 24
過去 30 日: 120
今までの合計 21,962
