メインコンテンツにスキップ
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
必要な工具と部品
  1. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 手順 1、 3の画像 1 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 手順 1、 3の画像 2 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: 手順 1、 3の画像 3
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • The rear hatch has both a left and right lift support strut.
  2. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 手順 2、 3の画像 1 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 手順 2、 3の画像 2 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: 手順 2、 3の画像 3
    • The struts are fastened with T40 Torx head bolts.
    • Use a T40 Torx driver to loosen the bolt
    • The bolt does not remove the strut. It is pressed in to the strut and will be replaced with the new strut.
  3. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 手順 3、 3の画像 1 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 手順 3、 3の画像 2 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: 手順 3、 3の画像 3
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This will stop the tailgate from sagging.
終わりに
To reassemble your Jeep, follow these instructions in reverse order.
8 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
oldturkey03
メンバー登録日: 09/29/10
781,527 ポイント
119のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
32 メンバー
531のガイドは作成済み
4 件のコメント
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Raymond Janko - 返信
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
oldturkey03 -
I need to replace the lower bolt as it snapped in half. Any advice for that?
Dave Hankins - 返信
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
oldturkey03 -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 57
今までの合計 9,878
