メインコンテンツにスキップ
1999-2004 Jeep Grand Cherokee Air Filter Replacement
必要な工具と部品
  1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement, Engine Compartment Air Filter: 手順 1、 1の画像 1
    • Before you start, make sure the car is off and the parking break is on.
  2. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 2、 2の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 2、 2の画像 2
    • Pull out the hood release handle, which will pop up the hood of the car.
    • The release is located by the driver's seat to the left of the peddles.
  3. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 3、 2の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 3、 2の画像 2
    • Unlatch the hood of the car.
    • Stick your fingers in the gap between the hood and the grill, and feel for a little latch.
    • Press on the latch while also pushing the hood of the car up.
    • Once the hood is unlatched, push it all the way up. It's held there by struts so don't worry about finding the hood prop.
  4. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 4、 3の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 4、 3の画像 2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 4、 3の画像 3
    • The air filter housing is on the right front corner of the engine compartment.
    • Unlatch all four of the clips , which are located at the corners of the air filter housing and hold the housing together.
  5. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 5、 2の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 5、 2の画像 2
    • Gently lift the top half of the housing, and hold it off to the side with one hand.
    • Don't pull the housing too far to the side because it is still attached to the rest of the engine.
    • You can use a flathead screw driver to help pry up the top of the casing.
  6. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 6、 2の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 6、 2の画像 2
    • Remove the old air filter and clean any debris out of the bottom half of the housing.
  7. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 7、 2の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 7、 2の画像 2
    • Place the new filter in the bottom half of the housing.
    • Make sure the air filter is positioned correctly with the mesh side facing up.
  8. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 8、 3の画像 1 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 8、 3の画像 2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 手順 8、 3の画像 3
    • Place the top half of the housing back on the bottom half. Make sure the top fits tight back in place.
    • Reattach all four clips on the outside of the casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kaylea Kleinschmit
メンバー登録日: 10/08/20
211 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S1-G11, Johnson Fall 2020 Linn Benton Community College, Team S1-G11, Johnson Fall 2020人のメンバー
LBCC-JOHNSON-F20S1G11
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 93
今までの合計 2,653
