メインコンテンツにスキップ
1999-2004 Honda Odyssey Trunk Struts Replacement
必要な工具と部品
  1. 1999-2004 Honda Odyssey Trunk Struts Replacement, Trunk Struts: 手順 1、 1の画像 1
    • IMPORTANT: Make sure to securely prop open the trunk with something sturdy. (if not have someone hold open the trunk)
  2. 1999-2004 Honda Odyssey Trunk Struts Replacement: 手順 2、 1の画像 1
    • Use a small flat head screwdriver to pry open the clip. Insert the screwdriver head into the smal opening. (this picture shows the clip closed)
  3. 1999-2004 Honda Odyssey Trunk Struts Replacement: 手順 3、 1の画像 1
    • Once the clip is open, simply pull the strut away from trunk. It might require a little force, but should easily come off. You may have to lift the trunk a little.
  4. 1999-2004 Honda Odyssey Trunk Struts Replacement: 手順 4、 1の画像 1
    • Repeat for the bottom strut. Open clip and remove strut.
    • Adding the new strut is easy. The strut should just snaps into place. You should hear a click when its on properly. Make sure to wiggle it a little to make sure its on.
    • You may have to lift the trunk to get the strut to fit at both ends.
    • Repeat on other side. I would recommend replacing the struts as a pair.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
pacopike1
メンバー登録日: 09/02/11
155 ポイント
1ガイドが承認済み
コメント 1 件
The replacement tailgate struts from Honda come with a dab of grease in the socket at each end of the strut. Check aftermarket struts for grease and add some yourself if there’s none.
Also, while the old strut is removed, check that the mounting ball bolts are tight. Two of mine were loose.
DaveT - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 3,033
