メインコンテンツにスキップ
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
必要な工具と部品
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: 手順 1、 3の画像 1 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: 手順 1、 3の画像 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: 手順 1、 3の画像 3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 2、 2の画像 1 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 2、 2の画像 2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 3、 3の画像 1 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 3、 3の画像 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 3、 3の画像 3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 4、 1の画像 1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 5、 3の画像 1 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 5、 3の画像 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 手順 5、 3の画像 3
    • Put back the light housing and screw in the two Philips screws.
終わりに
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,357 ポイント
23のガイドは作成済み
2 件のコメント
The problem is there are no screws to remove.
richard - 返信
there are no screws to remove on my 3rd light I can’t change the bulb
richard - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 50
今までの合計 6,018
