はじめに
People are stealing cars unsuccessfully and leaving cars with damaged door locks. Trips to Mechanical shops can be costly; sometimes, a procedure is effortless. Anyone can try to fix these functions, which will be a money saver. An issue with the key slot can be easily identified when there is no crucial slot to insert the car key into. Fixing the cylinder door lock of a 2001 Chevy Silverado takes little expertise and can be done within 30-45 minutes.
必要な工具と部品
With the angled screwdriver, remove the door handle trim and the door's plastic trim panel. One more time, with the help of the angled screwdriver, remove the window switch trim panel.
Now, the cylinder door lock is back in its place.
