メインコンテンツにスキップ
1998-2002 Honda Accord Tail Light Bulbs Replacement
必要な工具と部品
  1. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulb Assemblies: 手順 1、 2の画像 1 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulb Assemblies: 手順 1、 2の画像 2
    • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  2. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Panel Tail Lights: 手順 2、 3の画像 1 1998-2002 Honda Accord Tail Light Bulbs Replacement, Panel Tail Lights: 手順 2、 3の画像 2 1998-2002 Honda Accord Tail Light Bulbs Replacement, Panel Tail Lights: 手順 2、 3の画像 3
    • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
    • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
    • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  3. 1998-2002 Honda Accord Tail Light Bulbs Replacement: 手順 3、 3の画像 1 1998-2002 Honda Accord Tail Light Bulbs Replacement: 手順 3、 3の画像 2 1998-2002 Honda Accord Tail Light Bulbs Replacement: 手順 3、 3の画像 3
    • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  4. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Trunk Lid Tail Lights: 手順 4、 3の画像 1 1998-2002 Honda Accord Tail Light Bulbs Replacement, Trunk Lid Tail Lights: 手順 4、 3の画像 2 1998-2002 Honda Accord Tail Light Bulbs Replacement, Trunk Lid Tail Lights: 手順 4、 3の画像 3
    • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
    • Turn the light bulb sockets counterclockwise and remove them from their holes.
  5. 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulbs: 手順 5、 2の画像 1 1998-2002 Honda Accord Tail Light Bulbs Replacement, Tail Light Bulbs: 手順 5、 2の画像 2
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
終わりに
12 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Miroslav Djuric
158,300 ポイント
144のガイドは作成済み
4 件のコメント
Mine is a 2002 honda accord EX doest have that kind of fastener on the trunk's carpet... I don't know how to remove those!
Help!
JoeKehr13 - 返信
2001 Honda Accord Coupe - my stero turns on but has no sound, and the brake lamp indicator light came on and my headlights don't work now (running lights, yes). Could these all be connected to a fuse possibly? Help, I'm stuck in a parking lot!
Lindalace - 返信
Try your high beams, they should still work. And if you just replaced a break/tail bulb, then one of the skinny metal contacts inside the plastic sockets has bent down into the socket, causing the bad ground issue. Or your stereo illumination dimmer wire is exposed and shorting out.
Possibly the wrong bulb in one of the sockets as well.
Those are all I can think of right now.
Jax Kadar -
But what size of bulb should I get
Tommy Anguiano - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 78
今までの合計 81,199
