はじめに
Replace a shattered or fogged headlight unit in your '98-'02 Honda Accord.
必要な工具と部品
Pull on the hood release lever just inside the passenger door to pop the hood.
Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
Insert the hood prop rod into the hole in the hood marked with an arrow.
Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
The passenger side low beam bulb was extremely difficult to remove, owing to very little space to work in. Then I realized that the air intake could be rotated and pulled out. It was easier than removing the battery. After that it was very simple. I found it easier to first unscrew the bulb assembly, and then detach the connectors.
Thanks!
never seen or found a lever to push on top of connector, tho I do see it but it won’t pull of easy….a better picture or a close up and different description may help, I know to twist the back part of the bulb, I’ve done it before, but is giving me difficulty now, bulb won’t come out and harness won’t come off bulb either….very frustrating. 2002 accord
Locate and remove the bolts in the front of the wheel well on the either side of the car using a #1 Phillips screw driver or an 8 mm socket wrench.
Locate the bolts on the bottom of both corners of the bumper and remove them using an 8 mm socket wrench or box end wrench.
Remove the three 10 mm hex bolts securing the headlight bracket by turning them counter-clockwise with either a socket wrench or box end wrench,
Remove the headlight bracket by pulling it straight out.
13 の人々がこのガイドを完成させました。
6 件のコメント
On a '98 Honda accord ex, you can get to Step 2 and just change the lights.
i have a 1999 honda accord LX coupe, this guide is more difficult to follow, you can just go in with your bare hands to replace the marker light, you DO NOT HAVE TO REMOVE THE BUMPER! just reach down till you find it and twist it out and replace and put it back, this guide made it sound harder then it was, but its pretty easy. You will need the right bulb of course, but its so easy to replace then removing the entire bumper.
He was explaining how to replace the entire lens or headlight assembly not just a single headlight.
Why do my Blinkers and brake and. Dash – lights work but tail lights and headlights won't work on a 2000 Honda Accord
Como puedo resolver que las luces permanentes traseras y la pizarra no encienden todas las demás prenden
Yoan - 返信
También se prenden solas todas las luces
Yoan - 返信
