メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Use this guide to replace your 4-cylinder Honda Accord's distributor cap. This specific guide was created for a non-VTEC F23A5 engine, but other 4-cylinder Honda engines will be similar enough to follow the same basic steps
  1. Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap. The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle. Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
  2. Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine. The position of the third bolt is not visible in the second picture.
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  5. Pull the distributor cap away from the engine and set it aside.
    • Pull the distributor cap away from the engine and set it aside.
  6. Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange. Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
終わりに
9 の人々がこのガイドを完成させました。
Miroslav Djuric
150,594 ポイント
143のガイドは作成済み
4 件のコメント
I need to do this procedure. Have never done this in years. Next time I will change my wires, plugs and now my distributor cap.
Thurman - 返信
Where can I find the part number?
lawendellr - 返信
what about 6 cylinder
ssingam75 - 返信
excellent, thanks for you aportation.
julio cesar - 返信
コメントを追加
統計データを表示:
過去 24時間: 12
過去 7 日: 104
過去 30 日: 312
今までの合計 58,610
