メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
ツール
ツールは指定されていません。
  1. Prop up your hood.
    • Prop up your hood.
    • Make sure you prop your hood up with your hood prop rod.
  2. Locate the back of the headlight you plan to replace the bulb in.
    • Locate the back of the headlight you plan to replace the bulb in.
    • This will be directly behind the headlight assembly.
    • If you are replacing your left headlight, you may need to remove the battery to have enough room to do this replacement.
  3. Disconnect the headlight.
    • Disconnect the headlight.
  4. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  5. Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
    • Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
  6. Release the bulb by pushing the metal fastener inward and then moving it upwards. Release the bulb by pushing the metal fastener inward and then moving it upwards.
    • Release the bulb by pushing the metal fastener inward and then moving it upwards.
  7. Remove the bulb.
    • Remove the bulb.
  8. Insert the new bulb. Make sure the metal tabs fit correctly.
    • Insert the new bulb. Make sure the metal tabs fit correctly.
    • I've read that touching the glass on the bulb can shorten the life of the bulb, so try not to do that.
終わりに
To finish your headlight bulb replacement, follow these instructions in reverse order.
16 の人々がこのガイドを完成させました。
Chris Opperwall
メンバー登録日: 2013年04月04日
1,274 ポイント
1ガイドが承認済み
コメント1件
The 2000 and 2001 Camry models take 9006 (HB4) bulbs for the low beams and 9005 (HB3) bulbs for the high beams, rather than the 9003 (HB2) linked here -- at least for the North American models I've looked up.
If you have the original owner's manual that came with the car, there's a table of all the bulb types you'll need for different lights in the "Do-It-Yourself Maintenance" section. It doesn't hurt to double check.
rakslice - 返信
コメントを追加
統計データを表示:
過去 24時間: 9
過去 7 日: 59
過去 30 日: 307
今までの合計 43,004
