メインコンテンツにスキップ
1997-2003 Ford F-150 Power Side Mirror Replacement
必要な工具と部品
  1. 1997-2003 Ford F-150 Power Side Mirror Replacement, Power Side Mirror: 手順 1、 2の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement, Power Side Mirror: 手順 1、 2の画像 2
    • Search for retaining screws holding the door handle bezel. If there aren't any, that's your clue that it snaps into place. There should be a small opening on the edge of the bezel.
    • Place the tip of a flathead screwdriver into the gap and gently pry, it should begin to come off, at which point simply slide it off of the handle.
  2. 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 2、 3の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 2、 3の画像 2 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 2、 3の画像 3
    • There should be a small gap along the edge of the upper door trim. Place the tip of a flathead screwdriver in the gap and gently pry it off. There should be little resistance.
    • When reassembling, it should simply snap back into place.
  3. 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 3、 3の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 3、 3の画像 2 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 3、 3の画像 3
    • The window control panel may or may not have a small gap similar to the door bezel, this gap is merely for convenience. Should there be none: place the screwdriver on any edge and pry it underneath and then up and off.
    • Remove the window control panel just beneath the handle, it should snap into place just like the door bezel. Disconnect the wired connectors.
    • The connectors have a small pin that must be pushed in before they can detach, either use your fingers or a small Flathead screwdriver as shown in the pictures.
    • Similar to the door bezel and trim panels, use a flathead screwdriver and gently pry the panel off.
  4. 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 4、 2の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 4、 2の画像 2
    • Remove the two screws behind the door bezel and the small segment above the door. Grip the door trim and pull upwards, it should come off with little resistance but do not completely remove it as there is one last step before it can be fully detached.
  5. 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 5、 2の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 5、 2の画像 2
    • Before completely removing the door trim be sure to remove the door light. Twist it 180 degrees and it should pop out without any excess pressure.
  6. 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 6、 3の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 6、 3の画像 2 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 6、 3の画像 3
    • Now you should see a black material covering the door. This is called a vapor panel and protects the innards of the door form water and moisture. It should peel right off, but don't be afraid to use the screwdriver to gain leverage.
    • You will find another small connector similar to those found when disconnecting the window control panel. This operates the powered mirror and must be disconnected before the mirror is unscrewed.
    • Remove the small triangular portion of the vapor plate where the mirror mounts, you should see 3 large holes, inside which are the mounting screws for the mirror.
  7. 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 7、 3の画像 1 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 7、 3の画像 2 1997-2003 Ford F-150 Power Side Mirror Replacement: 手順 7、 3の画像 3
    • Once the screws are removed the mirror will fall. Either have another person there to catch it, or have the window rolled down so that you can stick your arm through it and hold it yourself.
    • Remove the three mounting screws, be sure the mirror does not fall, then line the new mirror up with the holes and reattach the screws.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Carter Clark
メンバー登録日: 03/07/19
172 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team S1-G9, Cools Stephens Spring 2019 Missouri Western, Team S1-G9, Cools Stephens Spring 2019人のメンバー
MWSU-COOLS STEPHENS-S19S1G9
1 メンバー
1のガイドは作成済み
コメント 1 件
what do you do if the cords behind the mirror tear like how would you go about replacing it then?
cam - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 57
今までの合計 5,112
