メインコンテンツにスキップ
1997-2003 Chevrolet Malibu Tail Lights Replacement
必要な工具と部品
  1. 1997-2003 Chevrolet Malibu Tail Lights Replacement, Tail Lights: 手順 1、 1の画像 1
    • Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
    • Unscrew the plastic casings.
  2. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 2、 1の画像 1
    • Make sure to put some pressure on the tail light itself so it does not fall out when you unscrew it.
    • Unscrew the three plastic wing nuts located behind the tail lights.
  3. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 3、 1の画像 1
    • When the tail light assembly comes loose, do not fully remove it because it may damage the connected wires.
    • Carefully pull the tail light away from the car to expose the connected wires.
  4. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 4、 3の画像 1 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 4、 3の画像 2 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 4、 3の画像 3
    • Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
    • Remove the rear panel from the rest of the assembly.
  5. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 5、 1の画像 1
    • Do not pull on the bulb, handle it gently because it is fragile.
    • Grab the plastic base of the bulb and gently wiggle it free.
  6. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 6、 1の画像 1
    • When handling the new bulbs, avoid touching the glass as much as possible because this can reduce the life of the bulb.
    • Gently push the new bulb into the plastic housing.
  7. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 手順 7、 1の画像 1
    • After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
    • These bulbs have different functions including blinkers, brake lights, hazard lights, and back-up lights. They will only turn on when the necessary signal is sent.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sank Yang
メンバー登録日: 10/03/12
484 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G15
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 46
今までの合計 19,406
