はじめに
Replacing the spark plugs in your Malibu can keep it running strong. New spark plugs will produce a stronger spark than older spark plugs allowing your engine to run smoother and more efficient.
必要な工具と部品
Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam.
もう少しです!
To reassemble your device, follow Steps 1-3 in reverse order.
終わりに
5 の人々がこのガイドを完成させました。
