はじめに
This guide will follow up on the removal of the front dash panel removal and show you how to access the actual stereo head unit.
ツール
パーツ
パーツは必要ありません。
Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
Push down on the tabs and remove the wiring from their blue and white harnesses.
These two are harder to remove than the others so do not be afraid to use force, or a flathead screw driver for leverage to pop them out.
As long as you are pushing the tab and force it out at a straight angle neither the plastic nor the wiring will be damaged.
2 の人々がこのガイドを完成させました。
