メインコンテンツにスキップ
1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement
必要な工具と部品
  1. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement, Valve Cover Gasket: 手順 1、 3の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement, Valve Cover Gasket: 手順 1、 3の画像 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement, Valve Cover Gasket: 手順 1、 3の画像 3
    • Pull the lever towards you to release the hood. You should hear a pop release coming from the front of the hood.
    • Push and hold the hood latch with the left hand and pull the hood up with your right hand to open.
    • Lock the hood stand into the two holes to keep the hood up located on the right-hand side of the hood.
    • Check the hood stand is secured and sturdy so that it doesn't collapse onto you.
  2. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 2、 1の画像 1
    • Visually inspect for any burns or black spots are usually an indication of an oil leak caused by a bad valve cover gasket.
  3. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 3、 2の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 3、 2の画像 2
    • Disconnect the battery by using the ratchet with a 10 mm socket.
    • Rotate the ratchet counterclockwise to remove the bolts.
    • Place the positive and negative terminal cables away from any contact with the battery or metal components.
    • Avoid contacting the terminal leads; arching/shocking will occur if the two-terminal leads touch each other.
  4. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 4、 3の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 4、 3の画像 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 4、 3の画像 3
    • Use tape to label the spark plug wires numbers 1 thru 4.
    • Pull the spark plug wires up or towards your upper body to remove them from the engine valve cover.
    • Twist and pull the air intake breather tube to remove it from the valve cover.
  5. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 5、 3の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 5、 3の画像 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 5、 3の画像 3
    • Remove the single 10 mm bolt that is attached to the spark plug fixture mount.
    • Remove the three 10 mm bolts in the front and the two 10mm bolts from the back of the valve cover in a counterclockwise motion.
    • Pull the valve cover up to remove it from the engine and place it aside.
  6. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 6、 2の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 6、 2の画像 2
    • Wipe and clean off the cylinder head surface using a shop towel.
    • Use a flat head screwdriver to help scrape in between areas that are difficult to reach.
  7. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 7、 3の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 7、 3の画像 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 7、 3の画像 3
    • Grip the square tab with your fingers and pull up to remove the valve cover gasket.
    • Install the new gasket with the square tab located to the lower right of the valve cover.
  8. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 8、 3の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 8、 3の画像 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 8、 3の画像 3
    • Install the valve cover back onto the engine.
    • Bolts will shear if over-tightened.
    • Install the five 10mm bolts onto the valve cover starting with the middle first follow by the outer bolts in an X-pattern fashion.
    • Install the single 10mm bolt with the spark plug wire fixture mount.
    • Install the spark plug wires back into the valve cover in numeric order that it was removed.
    • Install the air intake breather tube.
  9. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 9、 3の画像 1 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 9、 3の画像 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: 手順 9、 3の画像 3
    • Reconnect the battery cables starting with the black negative cable then the red positive cable.
    • Remove all tapes from spark plug wires.
    • Verify all bolts are installed and secured, then close the hood.
終わりに
Now that you have successfully installed a new valve cover gasket, the oil-burning into the atmosphere is now gone along with improving the engine's life.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kee Her
メンバー登録日: 01/05/21
206 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 111
今までの合計 3,530
