メインコンテンツにスキップ
1994-2004 Ford Mustang Headlight Replacement
必要な工具と部品
  1. 1994-2004 Ford Mustang Headlight Replacement, Headlights: 手順 1、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement, Headlights: 手順 1、 2の画像 2
    • To open the hood, pull the release lever by your foot break inside the car.
  2. 1994-2004 Ford Mustang Headlight Replacement: 手順 2、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 2、 2の画像 2
    • To raise the hood, lift up on handle at the front of the hood.
  3. 1994-2004 Ford Mustang Headlight Replacement: 手順 3、 1の画像 1
    • Pull on the edges until the cover pops off revealing the nut shown in the next step.
  4. 1994-2004 Ford Mustang Headlight Replacement: 手順 4、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 4、 2の画像 2
    • Using the 11mm wrench remove the nut.
  5. 1994-2004 Ford Mustang Headlight Replacement: 手順 5、 1の画像 1
    • Gently pull out the side paneling using your hands
  6. 1994-2004 Ford Mustang Headlight Replacement: 手順 6、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 6、 2の画像 2
    • Take out the turn signal light by twisting it. Remove the side panel.
  7. 1994-2004 Ford Mustang Headlight Replacement: 手順 7、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 7、 2の画像 2
    • Remove the bulb from the connector by pulling the two apart then, connect the new bulb to the connector.
  8. 1994-2004 Ford Mustang Headlight Replacement: 手順 8、 1の画像 1
    • In the same area where you removed the screw, remove the clip by hand or use needle nose pliers.
  9. 1994-2004 Ford Mustang Headlight Replacement: 手順 9、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 9、 2の画像 2
    • Identify the three retainers. Two of them are on the same side from which the metal clip was removed. The third is on the opposite side, shown in the next step.
    • Slide the 12mm wrench over the retainer and push until you are able to remove the headlight.
  10. 1994-2004 Ford Mustang Headlight Replacement: 手順 10、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 10、 2の画像 2
    • Third retainer. To push the retainers in so that I was able to remove the headlight, I pressed the handle of the wrench against the metal part of the retainers and pushed.
  11. 1994-2004 Ford Mustang Headlight Replacement: 手順 11、 2の画像 1 1994-2004 Ford Mustang Headlight Replacement: 手順 11、 2の画像 2
    • Similar to removing the turn signal, twist the headlight connector and remove the headlight from the bulb.
    • Disconnect the bulb from the connector by pulling the two apart and connect the new bulb. Attach the new bulb to the connector.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Josiah Crutchfield
メンバー登録日: 03/21/21
289 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S52-G3, Kim Spring 2021 University of Memphis, Team S52-G3, Kim Spring 2021人のメンバー
UM-KIM-S21S52G3
1 メンバー
1のガイドは作成済み
コメント 1 件
I am looking for a set of RHD headlights for my 1994 Mustang Cobra.
outlbw - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 92
今までの合計 1,270
