メインコンテンツにスキップ
1991-1996 Toyota Camry Oil and Oil Filter Replacement
必要な工具と部品
ビデオの概要
  1. 1991-1996 Toyota Camry Oil and Oil Filter Replacement, Oil and Oil Filter: 手順 1、 1の画像 1
    • Locate the oil filter under the exhaust manifold in the front of the vehicle
    • source.
  2. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 2、 1の画像 1
    • Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
    • source
    • Be careful not to burn yourself on the hot manifold.
  3. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 3、 1の画像 1
    • Unscrew the oil filter and let it drain into the oil drain pan
    • source
    • Make sure the pan is aligned to catch oil from both the filter and drain plug.
  4. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 4、 1の画像 1
    • Carefully remove the old oil filter
    • source.
  5. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 5、 3の画像 1 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 5、 3の画像 2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 5、 3の画像 3
    • Clean the mating surface where the new filter will be installed
    • Ensure there are no old seals or debris that could affect the new filter's seal
    • source.
  6. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 6、 1の画像 1
    • Install the new oil filter by hand tightening it
    • source.
  7. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 7、 2の画像 1 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 7、 2の画像 2
    • Move to the oil drain plug location and remove it using the 14mm socket and ratchet
    • source
    • Let the oil drain into the pan
    • source.
  8. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 8、 1の画像 1
    • Replace the old gasket on the drain plug with a new one, if necessary
    • source.
  9. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 9、 2の画像 1 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 9、 2の画像 2
    • Tighten the drain plug using the 14mm socket
    • source
    • Clean up any excess oil
    • source.
  10. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 10、 3の画像 1 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 10、 3の画像 2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: 手順 10、 3の画像 3
    • Refill the engine with 5W-30 oil using a funnel
    • source
    • This engine should take about five quarts
    • source
    • Be careful when filling the oil, as there is a plate just under the fill opening that can cause spills
    • source
    • Tilt the funnel to ensure the oil goes into the engine
    • source.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
eCuration
メンバー登録日: 05/19/17
376,693 ポイント
234のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 54
今までの合計 9,834
