はじめに
When a headlight bulb burns out, driving at night is more difficult and dangerous. Fortunately, replacing a headlight bulb is easy.
必要な工具と部品
To lift the hood of the car, pull the latch with the “hood up” icon up towards you. This latch can be found below the steering wheel and sits directly above where your left foot rests.
After lifting the hood of the car, click the latch (located just above the Toyota logo visible on the front bumper) holding the hood down upward. Lift the hood upward.
On the backside of the bulb socket, click the release lever down (as seen in the video). This will allow you to remove and replace the bulb
Pull the old bulb end (which rests just above the previously mentioned release level) up to remove it
Push new bulb end down until it clicks into position
7 の人々がこのガイドを完成させました。
