メインコンテンツにスキップ
1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement
必要な工具と部品
  1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement, Pressure Regulator Fuel Return Line: 手順 1、 2の画像 1 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement, Pressure Regulator Fuel Return Line: 手順 1、 2の画像 2
    • Pull the hood latch located underneath and left of the steering wheel until it unlatches. An audible "pop" will come from the hood when it has unlatched.
  2. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 2、 3の画像 1 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 2、 3の画像 2 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 2、 3の画像 3
    • Now that the internal latch is opened, a latch underneath the hood must also be unlatched. Put your fingers underneath the hood and lift up on the latch above and right of the Toyota emblem.
    • Remove the hooked end of the hood propping rod and allow it to pivot at the driver's side; place the hooked end in its receptacle to prop the hood.
  3. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 3、 2の画像 1 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 3、 2の画像 2
    • Inspect the line for damage such as cracks, holes, and fuel seeps.
    • Continue the repair if it shows signs of these failures. Otherwise, the fuel leak is coming from elsewhere.
  4. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 4、 2の画像 1 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 4、 2の画像 2
    • Use a Phillips #2 Screwdriver to loosen the hose clamps on the line until they move freely and are not constricting the hose.
    • Do not entirely unscrew the clamps, as they can be difficult to work with when fully unscrewed.
  5. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 5、 3の画像 1 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 5、 3の画像 2 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 5、 3の画像 3
    • Firmly grip the hose and pull one end outwards parallel from the main line. Repeat the process on the other end of the line.
  6. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 6、 2の画像 1 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 手順 6、 2の画像 2
    • Remove the hose clamps from the damaged line. Straighten the used line out and place it alongside the new hose, then cut a piece the same length with the hose cutter (a sharp knife will also work fine).
    • Place the hose clamps on the new hose. There is no need to replace the old hose clamps.
終わりに
作成者
2人の作成者と共同で作成されました。
Oliver Myers
メンバー登録日: 08/27/20
184 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 37
過去 30 日: 130
今までの合計 3,401
