メインコンテンツにスキップ
1986-1993 Volvo 240 Spark Plug Wires Replacement
必要な工具と部品
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: 手順 1、 1の画像 1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: 手順 2、 2の画像 1 1986-1993 Volvo 240 Spark Plug Wires Replacement: 手順 2、 2の画像 2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
終わりに
Install your new spark plug wires in the same manner that you removed the old ones.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
David Hodson
メンバー登録日: 04/13/10
150,503 ポイント
127のガイドは作成済み
2 件のコメント
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - 返信
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 4,020
