メインコンテンツにスキップ
1986-1993 Volvo 240 Front Struts Replacement
必要な工具と部品
  1. 1986-1993 Volvo 240 Front Struts Replacement, Front Springs: 手順 1、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement, Front Springs: 手順 1、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement, Front Springs: 手順 1、 3の画像 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or tire iron to remove the five 19 mm lug nuts from the front wheel.
    • Pull the front wheel off the wheel lugs and set it aside.
    We might need to re-arrange this.
    we jacked the car up and then cheated and used a impact gun
    if you don't have an impact gun you'll have to do it on the ground
    Scott Dingle - 返信
  2. 1986-1993 Volvo 240 Front Struts Replacement: 手順 2、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 2、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement: 手順 2、 3の画像 3
    • Use a socket wrench or impact gun to remove the 15 mm nut on the front sway bar endlink.
  3. 1986-1993 Volvo 240 Front Struts Replacement: 手順 3、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 3、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement: 手順 3、 3の画像 3
    • The front brake lines are attached to the body by a small bracket near the strut.
    • Grab the front edge of the bracket with a pair of locking pliers.
    • Without the locking pliers to hold the bracket in place, it may twist back and forth. This twisting could fracture the rigid brake lines.
    • Remove the 12 mm bolt that holds the bracket in place with a socket wrench.
  4. 1986-1993 Volvo 240 Front Struts Replacement: 手順 4、 2の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 4、 2の画像 2
    • Use a socket wrench or impact gun to remove the 19 mm tie rod end nut.
  5. 1986-1993 Volvo 240 Front Struts Replacement: 手順 5、 2の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 5、 2の画像 2
    • Place a tie rod end puller over the exposed threads of the tie rod end and turn the puller with a socket wrench to push the tie rod end out of the steering knuckle.
  6. 1986-1993 Volvo 240 Front Struts Replacement: 手順 6、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 6、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement: 手順 6、 3の画像 3
    • The ball joint is held to the control arm by three 18 mm bolts.
    • Remove the bottom two nuts with a breaker bar or long wrench.
    • Place a breaker bar over the gold nut on the bottom of the control arm.
    • The breaker bar alone will not be able to loosen the nut, since the bolt is free to rotate.
    • Place an 18 mm box end wrench over the bolt on top of the control arm.
    • Turn the breaker bar and the wrench in their respective counterclockwise directions to loosen and remove the third ball joint-to-control arm bolt.
    I have just finished replacing the shocks and mount. Instead of above, I found it convenient to remove the 4 bolts holding the ball joint plate to the strut pole. Don't forget to replace the old bolts with new OR at least use LocTite if you want to re-use the old bolts. DO NOT use a lot of the LocTIte, only a couple of drops, one on each side of the bolt. Use a big trolley jack and make it a good one. See the one in Step 9 - this is best for the job. If you can get the job done in a DIY garage then do it there. Consider the cost as a learning fee for yourself.
    Mick O'Connor - 返信
  7. 1986-1993 Volvo 240 Front Struts Replacement: 手順 7、 1の画像 1
    • Place a jack underneath the ball joint to support it once you remove the 3 ball joint-to-control arm bolts.
  8. 1986-1993 Volvo 240 Front Struts Replacement: 手順 8、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 8、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement: 手順 8、 3の画像 3
    • Open the hood and locate the three strut mounting bolts on the strut tower.
    • Make an alignment mark on the shoe at the dimple in the top of the strut tower before removing the mounting nuts.
    • Use a ratcheting socket wrench or impact wrench with a 13 mm deep socket to remove the three nuts.
  9. 1986-1993 Volvo 240 Front Struts Replacement: 手順 9、 1の画像 1
    • Slowly lower the jack and guide the strut assembly down and out of the car.
  10. 1986-1993 Volvo 240 Front Struts Replacement: 手順 10、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 10、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement: 手順 10、 3の画像 3
    • Place spring compressors on opposite sides of the spring.
    • Make sure you are using spring compressors that are meant for MacPherson struts. Internal-type spring compressors will not work.
    • Alternate tightening the spring compressors evenly until you are able to move the entire spring up and down.
  11. 1986-1993 Volvo 240 Front Struts Replacement: 手順 11、 3の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 11、 3の画像 2 1986-1993 Volvo 240 Front Struts Replacement: 手順 11、 3の画像 3
    • Use an impact wrench to remove the 24 mm nut at the top of the strut assembly.
    • Remove the strut mount from the strut assembly.
  12. 1986-1993 Volvo 240 Front Struts Replacement: 手順 12、 2の画像 1 1986-1993 Volvo 240 Front Struts Replacement: 手順 12、 2の画像 2
    • Remove the upper spring seat and pull the spring off the strut assembly.
    • If you are installing new springs you will need to remove the spring compressors. Loosen each spring compressor evenly, alternating from side to side until they are off the spring completely.
    • When installing new springs you will need to compress them with the spring compressors before placing them on the strut assembly.
    • If you are reinstalling the same springs you may keep the compressors in place until it is time to reassemble the suspension.
  13. 1986-1993 Volvo 240 Front Struts Replacement, Front Struts: 手順 13、 1の画像 1
    • Remove the rubber bump stop from the strut assembly.
  14. 1986-1993 Volvo 240 Front Struts Replacement: 手順 14、 1の画像 1
    • Use a large adjustable wrench or pair of groove joint pliers to remove the strut gland nut.
    I have had good luck using a:
    AutoCraft 2-3/8" 4 Lug Spindle Nut Wrench
    to remove the gland nut that holds the strut in the strut housing. I believe it is designed as a Ford/GM 4WD Locknut Tool
    Wesley Powers - 返信
  15. 1986-1993 Volvo 240 Front Struts Replacement: 手順 15、 1の画像 1
    • Grab the top of the strut and pull it out of the strut assembly.
    Excellent clarity with the photos AND description. I happened to do a search on “Specialized tools for the removal of Volvo 240 struts?” and found this article. So to me, the comprehensive tool listing to do a Volvo 240 strut job was absolutely great! Thank you most sincerely!
    Grayrider- 108 - 返信
    Very helpful for a newbie like me. Thanks a lot for sharing your knowledge.
    Dwi Ananto Widjojo - 返信
終わりに
15 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,493 ポイント
127のガイドは作成済み
10 件のコメント
This is so helpful. When I did this for the first time a while back, it took me and a buddy almost 9 hours to complete it. Now that I'm changing the other side, I decided to see if there were any guides online and WOW THIS IS SO HELPFUL. YOU ARE AMAZING FOR DOING THIS!!!
Parth Doshi - 返信
You note years 86-93. I have an 84 244 Turbo that I want to swap front strut assembly from 90 240. Will this work?
jerrod.slaughter - 返信
Just finished putting new struts and springs on 1990 Volvo 240 wagon. Your pictures and details were very helpful. It would be great if the breaklines could be removed from the strut boot.
Eric Zeko - 返信
thanks for the help you been most helpfull
Peter Cameron - 返信
IF you remove the brake caliper and disc it makes the strut assembly so much lighter and easier to handle.
Jo Black - 返信
Step 14 (removing the strut gland nut) was literally impossible for me. I live in an area with long winters and salted roads. All of the bolts and nuts gave me !&&*, but that one in particular was so rusted together that days of penetrating oil followed by torch heating had no effect. I just replaced the springs and gave up on the struts. This took me days to complete. I’d recommend paying a mechanic rather than attempting this if you live in a rusty area.
Steve Northup - 返信
The pictures were helpful for understanding disassembly, but I got to the step of removing the ball joint nuts and strut mount nuts before realizing this is a two-person job if you do not disconnect the brake line and ABS sensor, because there is no way in heck you can replace the strut while keeping the whole assembly stable, half out of the wheel well, but still connected via brake and ABS cables.
I understand that the way given above is quick and efficient versus fully removing the strut assembly from the vehicle, but a little note at the top saying it’s a two-person job would be appreciated.
Kyle Lotfi - 返信
I'm going to tackle my struts this weekend on my 1985 244 DL Volvo..Since this ( CORONAVIRS ) Is going on..Thanks alot ..and everyone BESAFE!!!
bigalbasketball41 - 返信
I'm going to tackle my struts on my 1985 244 DL Volvo, since this ( CORONAVIRS PANDEMIC ) Is going on..EVERYONE BE SAFE!!!!
Just finished my 1985 244 DL Volvo..this was very helpful..I am restoring the 1985..Thanks alot..
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 69
今までの合計 25,985
