メインコンテンツにスキップ
1986-1993 Volvo 240 Front Springs Replacement
必要な工具と部品
  1. 1986-1993 Volvo 240 Front Springs Replacement, Front Springs: 手順 1、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement, Front Springs: 手順 1、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement, Front Springs: 手順 1、 3の画像 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or tire iron to remove the five 19 mm lug nuts from the front wheel.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Springs Replacement: 手順 2、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 2、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement: 手順 2、 3の画像 3
    • Use a socket wrench or impact gun to remove the 15 mm nut on the front sway bar endlink.
  3. 1986-1993 Volvo 240 Front Springs Replacement: 手順 3、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 3、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement: 手順 3、 3の画像 3
    • The front brake lines are attached to the body by a small bracket near the strut.
    • Grab the front edge of the bracket with a pair of locking pliers.
    • Without the locking pliers to hold the bracket in place, it may twist back and forth. This twisting could fracture the rigid brake lines.
    • Remove the 12 mm bolt that holds the bracket in place with a socket wrench.
  4. 1986-1993 Volvo 240 Front Springs Replacement: 手順 4、 2の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 4、 2の画像 2
    • Use a socket wrench or impact gun to remove the 19 mm tie rod end nut.
  5. 1986-1993 Volvo 240 Front Springs Replacement: 手順 5、 2の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 5、 2の画像 2
    • Place a tie rod end puller over the exposed threads of the tie rod end and turn the puller with a socket wrench to push the tie rod end out of the steering knuckle.
  6. 1986-1993 Volvo 240 Front Springs Replacement: 手順 6、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 6、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement: 手順 6、 3の画像 3
    • The ball joint is held to the control arm by three 18 mm bolts.
    • Remove the bottom two nuts with a breaker bar or long wrench.
    • Place a breaker bar over the gold nut on the bottom of the control arm.
    • The breaker bar alone will not be able to loosen the nut, since the bolt is free to rotate.
    • Place an 18 mm box end wrench over the bolt on top of the control arm.
    • Turn the breaker bar and the wrench in their respective counterclockwise directions to loosen and remove the third ball joint-to-control arm bolt.
  7. 1986-1993 Volvo 240 Front Springs Replacement: 手順 7、 1の画像 1
    • Place a jack underneath the ball joint to support it once you remove the 3 ball joint-to-control arm bolts.
  8. 1986-1993 Volvo 240 Front Springs Replacement: 手順 8、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 8、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement: 手順 8、 3の画像 3
    • Open the hood and locate the three strut mounting bolts on the strut tower.
    • Make an alignment mark on the shoe at the dimple in the top of the strut tower before removing the mounting nuts.
    • Use a ratcheting socket wrench or impact wrench with a 13 mm deep socket to remove the three nuts.
  9. 1986-1993 Volvo 240 Front Springs Replacement: 手順 9、 1の画像 1
    • Slowly lower the jack and guide the strut assembly down and out of the car.
  10. 1986-1993 Volvo 240 Front Springs Replacement: 手順 10、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 10、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement: 手順 10、 3の画像 3
    • Place spring compressors on opposite sides of the spring.
    • Make sure you are using spring compressors that are meant for MacPherson struts. Internal-type spring compressors will not work.
    • Alternate tightening the spring compressors evenly until you are able to move the entire spring up and down.
  11. 1986-1993 Volvo 240 Front Springs Replacement: 手順 11、 3の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 11、 3の画像 2 1986-1993 Volvo 240 Front Springs Replacement: 手順 11、 3の画像 3
    • Use an impact wrench to remove the 24 mm nut at the top of the strut assembly.
    • Remove the strut mount from the strut assembly.
  12. 1986-1993 Volvo 240 Front Springs Replacement: 手順 12、 2の画像 1 1986-1993 Volvo 240 Front Springs Replacement: 手順 12、 2の画像 2
    • Remove the upper spring seat and pull the spring off the strut assembly.
    • If you are installing new springs you will need to remove the spring compressors. Loosen each spring compressor evenly, alternating from side to side until they are off the spring completely.
    • When installing new springs you will need to compress them with the spring compressors before placing them on the strut assembly.
    • If you are reinstalling the same springs you may keep the compressors in place until it is time to reassemble the suspension.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,997 ポイント
127のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 6,668
