はじめに
Replace a broken brake caliper or upgrade to bigger calipers for increased braking performance.
Removing the caliper requires disconnecting the brake hose, which will lead to losing brake fluid. When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
  1. Jack up the front of the car and place it on jack stands. Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death. Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper. Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. Lift the brake caliper off the rotor and set it aside. Place the caliper on some type of support so that you do not put too much strain on the brake hose.
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  5. Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper. Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
    • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
    • Detach the brake hose and remove the brake caliper.
    • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
まとめ
ある他の人がこのガイドを完成しました。
David Hodson
メンバー登録日: 2010年04月13日
134,277 ポイント
127のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 46
今までの合計 4,364
