メインコンテンツにスキップ
1986-1993 Volvo 240 Brake Master Cylinder Replacement
必要な工具と部品
  1. 1986-1993 Volvo 240 Brake Master Cylinder Replacement, Brake Master Cylinder: 手順 1、 1の画像 1
    • The brake master cylinder is located directly underneath the brake fluid reservoir near the driver side of the engine bay.
  2. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 2、 3の画像 1 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 2、 3の画像 2 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 2、 3の画像 3
    • Twist the brake fluid reservoir cap counterclockwise and remove it.
    • Remove as much brake fluid from the reservoir as possible by sticking a clean rag inside the reservoir.
    • When you remove the rag, be sure not to place it on any painted or plastic surfaces. Brake fluid will strip paint and deteriorate plastic.
  3. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 3、 2の画像 1 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 3、 2の画像 2
    • If your brake fluid reservoir has a fluid level sensor, disconnect it by pressing down on the plastic tab and pulling the connector straight out of its socket.
  4. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 4、 1の画像 1
    • Use a 10 mm open end wrench to disconnect the two brake lines from the master cylinder.
    • There were still be fluid in the master cylinder that will drip out of the connections; this is normal. Use a clean rag to clean up any dripping fluid.
  5. 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 5、 2の画像 1 1986-1993 Volvo 240 Brake Master Cylinder Replacement: 手順 5、 2の画像 2
    • Use an open end or socket wrench to remove the 17 mm nuts on either side of the master cylinder that attach it to the brake booster.
    • Remove the brake master cylinder, taking care not to damage or bend the brake lines.
終わりに
Don't forget to flush & bleed with new brake fluid! (separate how-to required)
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,503 ポイント
127のガイドは作成済み
3 件のコメント
Thanks this was great. Additional instructions are required about how to disconnect the reservoir from the master cylinder. I've broken so many plastic bits on my Volvo that I was scared to really put much force into getting the reservoir off. I kept thinking "There must be a trick..." but no there's no trick you just have to pull really hard while doing your best to not damage the reservoir. Could have saved me some time as I stared at it wondering what the "trick" could be.
There's also a plug on one side of the old master cylinder that you will need to take out and put on your new one.
Thanks again for posting these instrux.
Brant Louck - 返信
Thanks very much David Hopson & very helpful.
M. T Lam - 返信
David! Can you help!? Just got a 1991 Volvo 240 and the brakes went, just as you described. You mention that it is common with the 240? Can you elaborate?
Tracy Murphy - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 9,016
