メインコンテンツにスキップ
1985-1988 Volvo 740 Tire Rotation
必要な工具と部品
  1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Front Wheels: 手順 1、 1の画像 1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. 1985-1988 Volvo 740 Tire Rotation: 手順 2、 1の画像 1
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  3. 1985-1988 Volvo 740 Tire Rotation: 手順 3、 1の画像 1
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
  4. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Rear Wheels: 手順 4、 1の画像 1
  5. 1985-1988 Volvo 740 Tire Rotation: 手順 5、 2の画像 1 1985-1988 Volvo 740 Tire Rotation: 手順 5、 2の画像 2
    • Place jack head underneath frame couple (pictured).
  6. 1985-1988 Volvo 740 Tire Rotation: 手順 6、 2の画像 1 1985-1988 Volvo 740 Tire Rotation: 手順 6、 2の画像 2
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  7. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: 手順 7、 2の画像 1 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: 手順 7、 2の画像 2
    • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
    • Pull hubcaps away from tires.
  8. 1985-1988 Volvo 740 Tire Rotation: 手順 8、 1の画像 1
    • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  9. 1985-1988 Volvo 740 Tire Rotation: 手順 9、 1の画像 1
    • Remove tires by pulling directly away from car exposing brake rotors.
  10. 1985-1988 Volvo 740 Tire Rotation: 手順 10、 1の画像 1
    • Swap tires according to diagram.
  11. 1985-1988 Volvo 740 Tire Rotation: 手順 11、 1の画像 1
    • Place tires on axels.
    • Hand tighten the lug nuts with narrow end of nut towards car.
    • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
終わりに
作成者
3人の作成者と共同で作成されました。
Garrett Van Ruiten
メンバー登録日: 10/11/10
54 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S3G28
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 2,636
