メインコンテンツにスキップ
1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance
必要な工具と部品
  1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: 手順 1、 2の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: 手順 1、 2の画像 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 2、 2の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 2、 2の画像 2
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 3、 2の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 3、 2の画像 2
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 4、 2の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 4、 2の画像 2
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 5、 1の画像 1
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 6、 2の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 6、 2の画像 2
    • Clean the electronic coupling with an electronics cleaner.
  7. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 7、 2の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 7、 2の画像 2
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 8、 3の画像 1 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 8、 3の画像 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 8、 3の画像 3
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 手順 9、 1の画像 1
    • Reattach the electronic cable to the MAF.
終わりに
作成者
7人の作成者と共同で作成されました。
Isaac Nitschke
メンバー登録日: 10/11/10
67 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S3G28
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 25
今までの合計 9,735
