メインコンテンツにスキップ
1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement
必要な工具と部品
  1. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement, Tire Tube: 手順 1、 3の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement, Tire Tube: 手順 1、 3の画像 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement, Tire Tube: 手順 1、 3の画像 3
    • Shift the bike into the smallest gear.
    • Move the gear levers up to the highest position.
    • Move the bike pedals forward with your hands or ride the bike to make sure the gears change.
    • The bike should make a clicking noise and the chain should shift to the smallest gear.
    • Make sure that the chain has a lot of slack.
  2. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 2、 1の画像 1
    • Place the bike upside down.
    • Placing the bike upside down is important when doing maintenance on a bike because it keeps the bike stable and easy to work with.
  3. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 3、 3の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 3、 3の画像 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 3、 3の画像 3
    • Potential for device damage: When the tire is removed DO NOT engage the brakes because they can become stuck together.
    • Caution: When feeding the chain, be sure not to get your fingers caught between the gears.
    • Remove the nuts and bolts.
    • If you are having trouble loosening the nuts, use a rag to move the 15mm wrench.
    • Feed the chain by rotating the wheel and move the chain away from the gear.
    • Pull out the back wheel and make sure the chain remains attached to the frame of the bike.
  4. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 4、 1の画像 1
    • Unscrew the tire valve.
    • Push down with the end of the tire lever to deflate the tire.
    • Deflating the tire makes it significantly easier to remove the tubing later.
  5. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 5、 2の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 5、 2の画像 2
    • Loosen the tire using a tire lever.
    • If your tires are in bad condition, small fragments of rubber may fall out of the rims.
    • Push the tire lever into the crease of where the metal meets the rubber of the tire.
    • Push the lever along the crease of the tire.
  6. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 6、 3の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 6、 3の画像 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 6、 3の画像 3
    • Place the wheel on a small rag to prevent scratching the rims.
    • Pull out the tubing.
    • Depending on the condition of your bike, the tubing may be difficult to pull out at first.
    • Remove the valve from the rim by pushing it down into the hole.
    • Remove the tubing.
  7. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 7、 2の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 7、 2の画像 2
    • Place the new tube over the bike rims.
    • You should be able to easily insert the deflated tubing back into the creases of the tire.
    • Look for the small hole in the rims.
    • Insert the valve.
    • Insert the rest of the tubing.
    • Tuck the tires back into the rims.
    • If you’re having trouble tucking the tire back in, try using the tire lever to tuck the tires back into place.
  8. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 8、 3の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 8、 3の画像 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 8、 3の画像 3
    • Inflate the new tire.
    • Inflating the new tire before placing it back on the wheel is important. It makes imperfections visible and easily correctable.
    • Insert the end of the bicycle pump into the valve of the new tire valve.
    • Lock the pump into place using the lever at the end of the pump.
    • Pump the tire until the pump reads roughly 75 psi.
  9. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 9、 3の画像 1 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 9、 3の画像 2 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 9、 3の画像 3
    • Attach the back wheel onto the bike.
    • This step is vital because the wheel could fall off if not properly attached. The tire and frame may also grind together and damage the tire.
    • Feed the chain back onto the pedal gear and the back-wheel gears.
    • Straighten out the tire with the blunt end of the hammer.
    • Tighten the nuts and washers using the 15mm sprocket wrench on one side and the 15mm wench on the other.
    • Tightening both bolts at the same time ensures that the tire is straight.
  10. 1982 Schwinn World Sport Bicycle Rear Wheel Tube Replacement: 手順 10、 1の画像 1
    • Flip the bike back over.
    • Congratulations, you've successfully replaced the tubing!
ゴール
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nicholas Espinosa
メンバー登録日: 02/18/21
202 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G11, Raign Spring 2021 University of North Texas, Team S1-G11, Raign Spring 2021人のメンバー
UNT-RAIGN-S21S1G11
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 735
