Find the car battery under the hood.
On the battery locate the black negative battery terminal.
Next unscrew the knob on the disconnect.
Lastly move the negative lead away from the batter terminal.
Make sure not to cross the battery leads.
You are now ready to start replacing the speaker.
A philips head screwdriver will be needed.
Do not use a socket in this situation because it may mess up the speaker guard.
Lastly make sure to remove the screw completely without stripping out the screw hole.
Place the speaker back into the kick panel housing.
Line up the speaker holes with the existing holes in the kick panel.
Be careful not to pinch the speaker wires.
This would be a good time to replace the speaker wires if needed
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
