メインコンテンツにスキップ
12-String Takamine G Series Guitar String Replacement
必要な工具と部品
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: 手順 1、 3の画像 1 12-String Takamine G Series Guitar String Replacement, Guitar String: 手順 1、 3の画像 2 12-String Takamine G Series Guitar String Replacement, Guitar String: 手順 1、 3の画像 3
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
  2. 12-String Takamine G Series Guitar String Replacement: 手順 2、 2の画像 1 12-String Takamine G Series Guitar String Replacement: 手順 2、 2の画像 2
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
  3. 12-String Takamine G Series Guitar String Replacement: 手順 3、 2の画像 1 12-String Takamine G Series Guitar String Replacement: 手順 3、 2の画像 2
    • Place the new string into the hole in the bridge where the pin was taken out.
  4. 12-String Takamine G Series Guitar String Replacement: 手順 4、 3の画像 1 12-String Takamine G Series Guitar String Replacement: 手順 4、 3の画像 2 12-String Takamine G Series Guitar String Replacement: 手順 4、 3の画像 3
    • Place the pin back into the hole to secure the string.
  5. 12-String Takamine G Series Guitar String Replacement: 手順 5、 1の画像 1
    • Grab the string and put it through the hole located on the tuning post of the guitar.
  6. 12-String Takamine G Series Guitar String Replacement: 手順 6、 3の画像 1 12-String Takamine G Series Guitar String Replacement: 手順 6、 3の画像 2 12-String Takamine G Series Guitar String Replacement: 手順 6、 3の画像 3
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
  7. 12-String Takamine G Series Guitar String Replacement: 手順 7、 2の画像 1 12-String Takamine G Series Guitar String Replacement: 手順 7、 2の画像 2
    • Turn the tuning peg counterclockwise to tighten the string.
終わりに
作成者
2人の作成者と共同で作成されました。
Rey Navarro
メンバー登録日: 09/27/23
145 ポイント
1ガイドが承認済み
チーム
University of Arizona, Team 6-34, Cools Stephens Fall 2023 University of Arizona, Team 6-34, Cools Stephens Fall 2023人のメンバー
ARIZONA-COOLS STEPHENS-F23S6G34
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 83
