メインコンテンツにスキップ
(Fat) Xbox 360 Hard Drive Replacement
必要な工具と部品
  1. (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 手順 1、 3の画像 1 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 手順 1、 3の画像 2 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 手順 1、 3の画像 3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. (Fat) Xbox 360 Hard Drive Replacement, Disassembly tip: 手順 2、 1の画像 1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 手順 3、 3の画像 1 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 手順 3、 3の画像 2 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 手順 3、 3の画像 3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 手順 4、 3の画像 1 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 手順 4、 3の画像 2 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 手順 4、 3の画像 3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
ゴール
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
88,752 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 37
過去 30 日: 220
今までの合計 9,160
