メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
(Fat) Xbox 360 Hard Drive Replacement
必要な工具と部品
  1. この手順で使用する道具:
    Essential Electronics Toolkit
    $29.95
    • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
    • If you are interested in a refurbished kit stock levels change frequently but can be found here.
  2. (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 手順 2、 3の画像 1 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 手順 2、 3の画像 2 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 手順 2、 3の画像 3
    • EET owners: Your kit has this bit. No purchase needed.
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  3. (Fat) Xbox 360 Hard Drive Replacement, Disassembly tip: 手順 3、 1の画像 1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  4. (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 手順 4、 3の画像 1 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 手順 4、 3の画像 2 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 手順 4、 3の画像 3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  5. (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 手順 5、 3の画像 1 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 手順 5、 3の画像 2 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 手順 5、 3の画像 3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
ゴール
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
99,497 ポイント
63のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 62
過去 30 日: 368
今までの合計 16,889
