メインコンテンツにスキップ
Samsung NX1000 Back Panel Replacement
必要な工具と部品
  1. Samsung NX1000 Back Panel Replacement, Removing the Back Panel: 手順 1、 1の画像 1
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Samsung NX1000 Back Panel Replacement: 手順 2、 2の画像 1 Samsung NX1000 Back Panel Replacement: 手順 2、 2の画像 2
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Samsung NX1000 Back Panel Replacement: 手順 3、 2の画像 1 Samsung NX1000 Back Panel Replacement: 手順 3、 2の画像 2
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Samsung NX1000 Back Panel Replacement: 手順 4、 2の画像 1 Samsung NX1000 Back Panel Replacement: 手順 4、 2の画像 2
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Samsung NX1000 Back Panel Replacement: 手順 5、 3の画像 1 Samsung NX1000 Back Panel Replacement: 手順 5、 3の画像 2 Samsung NX1000 Back Panel Replacement: 手順 5、 3の画像 3
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  6. Samsung NX1000 Back Panel Replacement: 手順 6、 2の画像 1 Samsung NX1000 Back Panel Replacement: 手順 6、 2の画像 2
    • Completely separate the back panel from the camera.
  7. Samsung NX1000 Back Panel Replacement, Back Panel Components: 手順 7、 2の画像 1 Samsung NX1000 Back Panel Replacement, Back Panel Components: 手順 7、 2の画像 2
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  8. Samsung NX1000 Back Panel Replacement: 手順 8、 3の画像 1 Samsung NX1000 Back Panel Replacement: 手順 8、 3の画像 2 Samsung NX1000 Back Panel Replacement: 手順 8、 3の画像 3
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  9. Samsung NX1000 Back Panel Replacement: 手順 9、 1の画像 1
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  10. Samsung NX1000 Back Panel Replacement, Back Panel: 手順 10、 3の画像 1 Samsung NX1000 Back Panel Replacement, Back Panel: 手順 10、 3の画像 2 Samsung NX1000 Back Panel Replacement, Back Panel: 手順 10、 3の画像 3
    • Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
  11. Samsung NX1000 Back Panel Replacement: 手順 11、 2の画像 1 Samsung NX1000 Back Panel Replacement: 手順 11、 2の画像 2
    • Separate the back panel from the LCD.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Greg Baghdikian
メンバー登録日: 01/22/15
143 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 20-13, Maness Winter 2015 Cal Poly, Team 20-13, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S20G13
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,426
