この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
必要な工具と部品
首先先将飞利普灯泡的玻璃小心地清除掉,在这个示例中,玻璃已经事前就清除了。
使用沟槽钳来轻轻地旋转并破坏螺口
一旦取出螺口,就可以用手拉出LED控制器,可能需要再次使用沟槽钳。
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
84%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
8 件のコメント
Can't wait to try it! I really didn't want to lose this color hue bulb, so this is a great way to extend the life of these bulbs
You’re exactly the kind of person who is in the situation for which I posted this guide :) :) :)
fingers crossed for you !!
Is there any other model that fits better into the Philips Hue? I broke one and want to fix it but I see on your pictures that the Ikea bulb doesn’t fit perfectly.
maybe we can find another model that fits into the Hue base…
in any case I want to thank you for the guide! Good idea to repair Hue bulbs
Hi !
sorry for missing your comment !
i have no idea to be honest. This is a easy hack that worked fine for me since my bulbs are in an enclosure :)
hope you found something that worked for you !
Great stuff! Has anyone tried unscrewing the three screws seen on the second picture under step 1? I figure that would make it easier to get all of the broken glass out of the way and start with a clean slate before gluing the new glass on there. I just don’t know if there are any cables under there that would break or something of that nature, and don’t really want to find out if I risk breaking the entire thing.
Maybe someone with a completely dead bulb could try it and snap some pictures? Fingers crossed!
Okay, so after further research the plastic piece held down by the three crews is just a lid. It lifted up with a bit of pursuasion due to the glue/silicone mold. Do note, though, that there are different designs out there. My bulb has a star pattern LED layout. In my case lifting the lid made it easier to completely remove the shattered glass. Good luck ya’ll.
Hi David !
thanks for putting your own feedback to the guide ! I’m glad that you found a way
I personnaly had to apply extra « force » on several parts but overall removing the glass was quite easy !
good luck with the fixing process
Vincent
(puts on snotty internet know it all voice) Uhm, actually....
Colloquially speaking, though from a more technical point of view, the globe shaped piece you replace is the diffuser, as the entire unit is considered the 'bulb' (A19 form factor IIRC).
For those wondering, any old led bulbs diffuser could be used. Just gently work around the joint between the diffuser and plastic (usually encasing aluminum) body with a sprudger to separate the silicone caulk like glue bonding them together. Though do take a moment to take notice of the plastic thickness and density (tap it, squeeze it. Does it sound thin and bendy, or brittle, or denser with more of a slight give than a crumpling bend), some plastics are not be suited for the heat of a higher output unit. Remember, LED power supplies and pwm switching circuits tend to dump a bit of heat, especially when ran at near or even over max ratings like most manufacturers do. Also remember to choose an adhesive that can perform in a hot environment without failing.
