看看吧,我们可爱的小家伙。从外观来看相当时尚了,再来看看规格吧:
安乃达 250 W, 36 V M108RL高速电动机
0.21 kWh 电池 (20 NCR18650PF 锂电池)
单次充电助力骑行 45 km
禧玛诺 Nexus 三变速器
根据人脚踏调节的力矩传感助力
骑行数据实时监测,包括速度、里程、动态功率和卡路里消耗。
对于那些不熟悉可折叠电动自行车的,这里是另一个经典的、类似 Brompton 折叠自行车,用于比较。 (这比我们通常的比较要宏观些。)
骑记车轮有一个较小的轴距(870 mm)与较小的轮胎(16'')。固定的车把和坐垫最大下降尺度有限(坏消息,骑车人身高必须超过5'6”/ 170 cm )。
内置自行车计算机可在四种功率模式之间切换,并监视实时骑行数据。 (智能手机应用程序也有很多信息)。
I bought one of this but how can i change LCD language from chinese to english?
Stessa domanda come si aggiorna a inflese
. Dolcclod - 返信
废话少说,让我们从最简单的部分开始拆:座垫。快速释放两个管夹后,它就拆下来了!
座椅柱将后摇臂锁定到位,因此一旦拆下,自行车就可以折叠起来。
接下来拧下花哨的折叠踏板。该机制在折叠时减小自行车的总宽度。
What are the dimensions of the seat post? Also, can it be replaced with one with suspension? If so, what brands/models do you recommend?
Hi Alberto, I have a Dahon 33.9 Thud buster long travel seat post from my Dahon jetstream folding bike, the Qicycle also has seat post size 33.9. When I tried the Thud buster on my Qi cycle I ran into a problem with metal shims inside the Qi cycle seatpost keeping the Thud buster from sliding in unfortunately. Hope this helps.
链条在后轮部分的外面,有一个方便的后链担架,使拆除很简单。
车链具有52个链轮,而后轮毂齿轮则有14个链轮。这使我们在第一档的比例为1:2.7,在第二档的比例为1:3.7,在第三档的比例为1:5。
链条本身有96个链接。没有用于打开链条的主链接 ,但是标准链工具可以拆开任何链接。
So the chain is a single speed Narrow (3/32) or Wide (1/8)?
Thanx
Michele
Chain is wide and I think the chain line is not right. The chain makes a noise not unlike poorly adjusted derailleur transmission. The cog appears to be Y32203200 and seems to me the only reason to use a wide chain. It is deeply dished to get clearance from the hub and moves chain out of line with the chainring.
I was mistaken in thinking the wide chain was needed only because of the 14t cog. I think I can get better chain line with 16t nexus sprocket but still have to use that wide chain. Not going very fast by pedaling, but pretty easy to climb even without any assistance.
取出齿轮盘需要做一些准备,在使用齿轮拆卸扳手之前必须先取下盖子。但之后,它像任何其他自行车齿轮盘一样弹出。
拼图中下一个动力传送装置是中轴。
同样,我们需要一个标准的自行车工具——中轴拆卸工具 ——来撬松这硬件。
can we replace the bottom bracket with standard ceramic bearing bb out there in the market?
which is the size of the bottom bracket?
i would like to swap the plastic cheap one for one of better quality.
kind regards
from this video, the man replaced it with the
Central movement FSA RPM 7420 68x118mm
Hey Guys, can someone tell me what is the size of the screws holding the crank? I unfortunately lost the right one and now I have a crank loose, therefore I will not be able to ride the bike until I get a replacement.
The later version has a different bottom bracket. The chain ring is attached to bottom bracket and not the crank arm. I guess it is possibly OEM variant of Ananda bottom bracket S15. It says bbts1sd on a sticker attached to the frame.
Si quelqu'un peut donner les infos après démontage du modèle ef1 ou/et ef2 ce serait top ;-)
米家骑记电助力自行车一个不错的功能是这个禧玛诺 Nexus 3速车轮轴。我们很容易卸下曲柄,并取出在轮轴内部的螺帽。
在自行车的另一端,我们把橡胶把手拽下来,拆除变速器把手。
devo cambiare copertone quindi devo togliere la ruota, in che marcia (rapporto) devo mettere per togliere la ruota dalla bici?
voi avete scritto in marcia (rapporto) n3 ma nella figura mostrate che sta in marcia (rapporto) n1
qual’è la maniera corretta per togliere quindi la ruota dalla bici? deve essere inserita la marcia - rapporto 1 o devo inserire la 3 ?
ed invece se voglio smontare il cambio deve eressero in che marcia (rapporto) ? nella marcia 3?
se voglio regolare il cambio ho capito che deve essere nella marcia (rapporto) 2
Ciao ragazzi, come fare a regolare il freno posteriore?
Il mio frena troppo poco, devo praticamente tirare del tutto la leva per avere un effetto frenante di un certo livello.
Grazie!
Peut-on remplacer ?
BR-IM31-R 520 grammes d'origine par:
BR-C3000-R ou
BR-C3010-R mm +10% de puissance de freinage ou
BR-C6000-R poids 660 grammes
当然,要它不是智能自行车,我们也不会拆解它。所以到了我们检查速度传感器的时间了。
电线连接在座椅下方,然后沿着框架延伸到(模块化)插座。
我们能够剥离电线,并拆下传感器组件。
How we can disable the speed limit?
It's imposed by the software.
The Chinese firmware limits the assist to speeds under 20km/h. The European aids you until you reach 25km/h. An unofficial firmware sets the limit speed up to 29km/h I think.
My bike has bb torque sensor of type bbts1sd, I can't find any info on that. Looks like it has external bearings. Bike frame doesn't have any qicycle or mijia decals (only tiny mi decals here and there) and it looks like it was thinly sprayed over with matte black paint. I paid €1000 for it, it's an unused bike with full warranty. Manufactured in 2020.
推出小电路板,我们得到这个奇迹测量器的核心:
三线系统使用简单的 JST 连接器连接,而不是焊接。现在这就是我们所说的模块化。
It does measure rpm but likely not the wheel but rather the sprocket. This piece of data is then combined with the amount of deflection the chain shows. Nothing much on a city bike like this so the sensor needs to be super sensitive so super expensive. Later versions of this bike use cheaper sensor located at the bottom bracket.
拧下盖子后,我们可以推出旋转运动的源头,并发现电机后盖后面的一个小圆形板。
除了分配功率,它还具有用于(每四个线圈)测量速度的三个传感器。
翻转侧的三个齿轮由塑料制成,以将磨损保持在最小。
Ist der Hersteller des Motors bekannt bzw. nach dem Öffnen zu Erkennen ?
Kann es sein, dass der Motor hergestellt wird von:
Changzhou Huayu Xinfeng Motor Co.ltd ?
Hallo Joerg, den Hersteller des Motors konnten wir bislang noch nicht herausfinden. Die Aufgedruckte Nummer am Motor gab auch keinen Aufschluss über die genaue Herkunft (MV8536VN2C5AN16GF2648). Huayu Xinfeng Motor Co.ltd stellt einige verschiedene Motoren her, jedoch habe ich auf den ersten Blick diesen Motor nicht darunter entdeckt.
Please I'm not quite get how to open the hub motor, I've already unscrew 3 screw on the cover lid, still the hub not open, please help.
consigue 3 tornillos de la misma medida, pero mas largos, retiras los tornillos originales, y pones los largos, y haces fuerza en contra de la manecilla del reloj. Si aún asi no puedes, entonces, calca los orificios en una lamina de madera, tres huecos para los tornillos, y un hueco mas grande en el centro, algo asi:
______________________________________________________
_______________________________________________O_____|
______________________________________O__( o )________|
______________________________________________O______|
______________________________________________________|
john -
Same problem here, did you manage to open it? because no answer after 2 years….
Why the planetary gears are plastics?
Does they transfer the power too?
Hi, when looking at the specs for this motor, it clearly says 30Nm, while i know xiaomi has 7,3 Nm in their spec sheet. I think Xiaomi got it wrong and is under selling the torque http://ananda.com.cn/index.php/wap/produ...
I suspect the value given by motor manufacturer is when you use a cheap square wave controller. Here Xiaomi has chosen enough computational power to run a much better sine wave controller, resulting however a pretty expensive bike for what it is. Well, it says smart in it's name at least where I live. They make another version in their himo range that comes with bigger wheels or some kind of rear suspension cast wheels and disk brakes. They are likely punchy and noisy just like some people like. And drive like a moped if fitted with a throttle lever.
how could I disassembly the front-hub after removing that little three side cover screws?
Hi, in case we need to replace the plastic gears can we buy them anywhere? or should we make them?
Who is the engine manufacturer?
现在,欢迎来到 拆解中。
我们剥离了大多数自行车零件。留下的铝骨架重5.5公斤,超过总重量的三分之一。
我们继续从顶管拉出主插头,使我们能够提取连接所有电子元件的神经系统。
The available parts appear to be for the Chinese version with an accelerator lever. Later versions of eu conforming bikes have yet another kind of harness with wires from the brake levers.
Did you found the Eu version of the harness ?
I have the same problem and can't find the good one.
Thanks
did anyone find this af of yet? mine broke as well in the eu version
只有4个 Torx 螺丝固定自行车计算机的盖子与 160 × 128 像素的 TFT 屏幕用简单的 ZIF 连接器连接。
在板的另一面,我们找到以下芯片:
联发科 MT6261A ARM 处理器
Microchip PIC16LF1518-I/MV PIC 控制器
CSR 1010D A05U 蓝牙智能IC照明
德州仪器TPS259240 eFuse 带过压保护
Winbond 25Q128FV 128 Mb 串行闪存
意法半导体加速度计
How to factory reset the trip computer?
Hi ifixit,
How did you remove the metal plate that protects the MTK 6261A CPU and the Winbond 25Q128FV CHIP ?
Best Regards
Carefully ;) but with the help of a side cutter. Removing those shields is not recommended and might effect the function of the chips.
Hey !! Take a look at this playlist.
30 minutes, and you will have your translated QiCycle !!
Hello I accidentally dropped the bike and the cover of the bike computer is cracked (thankfully the display looks to work fine). Any ideas where I can get a spare accessory for that cover?
I have a same issue did you find the computer mont?
Thanks
Still haven’t found a spare part for this. It looks like you could get the whole display from Aliexpress but they don’t sell it any more.
loukis -
Same problem for me, just received and the under-cover of that accesory arrived broken..
Hi there, I have the same problem, unfortunately the guy that sold me the bike told me that during the shipping the display holder has got damages, now it’s more or less fixed but I would like to change it, without changing the whole thing that is perfectly working…
Do you know how could I do it?
A guy in Spain is selling screen protectors.
His mail: felixfazer@gmail.com
Xiaomi Qicycle EF1 protector de pantalla
where can i find a new screen or a new bike computer?
mine is broken.
thanks
Hi santos. You might want to check out the additional link (wordpress page) here: MiJia QiCycle Folding Electric Bike
no display to buy :( thanks
我们把最棒的、或至少最强大的电池管保留到最后拆!
该管可以单手取出,只需按下一个按钮,可以用5针连接于侧面在3小时内充电。
自行车的重量大部分来源于这个电池——它重1.46公斤,当然是充满电的时候。 ;)
自行车的电池容量重为5800mAh(208.8Wh)。上一个无意义的比较,电量超过5 个12.9英寸的 iPad Pro 12.9"!
我们开始撬开后灯,电缆保持在适当位置,但能看到一些隐藏的螺钉。进入内部就有办法啦。
这个大型脐带从充电端口通向另一端的电池和BMS(电池管理系统),并在后灯后面有一个LED板。
我们剥掉电路板,发现一些秘密。这个电路控制后面的LED阵列,以及沿管顶部的一些LED(可能指示电池活动)。
I’m having trouble prying out the rear light. It’s pretty stuck in my case. What kind of force should be used? Should I rotate it? Or should I pull it?
We used a heavy duty suction cup for a better grip. Try turning it counterclockwise. It sits very tight.
I had to use a craft/hunters knife to slowly pry it apart then suction cupped it off once loosened
R E-cycled - 返信
主电池盒很难打开。五个螺丝(隐藏在一些很难撬开的盖子下)并不是全部。
当我们在一些温和的加热和“良好的振动”下最终成功打开的外壳,搞坏了一些芯片。自行更换电池恐怕不行。
我们终于拿到了奖品:20 个松下NCR18650PF锂离子电池!松下是一个很好的(安全)品牌,所以充电应该是很容易地,即使自行更换容易。
电池组还具有电池管理系统(BMS)电路板。
Hello, I build and repair Ebike Battery Packs, see ebike-workshop.com, yes it would be possible to charge this Pack using a separate Pack, but proble is:
- the extra pack supplies too much current, the BMS Charging board would be distroyed or stop this “Super-Charging”, since it is not made for currents above 2-3 Amps. higher Charging currents would also reduce lifetime of the internal 18650 Cells
What you would need is an additional, external 36v (fused!) batteryPack which is connected directly to the Battery + - and increases the internal capacity like I suggested for M365 E-Scooter on my website. this would be permanently connected and can be charged with the original charger.
Who knows if it's possible to replace the cells with the more capacitive ones?
yes it seems possible to change the cells with higher capacity than the original 2900mAH make sure to buy the right format 18650 with at least a Continuous Discharge Rating of 10A. I advise to buy a few more cells to test that all cells are around same (not sure what to check and with what?) .
What tools or technical works is need to replace the cells once the battery is opened?
Could you say more about the gentle vibrations?
I’ve been trying to open the battery without much luck. So far, I managed to split the part near the seatpost. I’ve used all my own force to crack it open without luck.
Do you have further tips and pointers?
So I finally managed to open it by creating a lever to amplify the force to crack it open. To my own surprise, my battery contained Samsung 29E cells. The battery cells were built together very well, with several protection mechanisms in place, including a heat sensor.
IR Here -
I’ve stripped out the cells and the BMS. Then I wired a new battery pack directly to the GND and VCC. I’ve done a test ride of 5 km and it’s working well.
Few notes:
- backlight doesn’t work anymore
- the display always shows “low voltage”
IR Here -
Hi am trying to replace the original battery with another one . Could you please send me som pictures or provide me with the controller diagram pins that goes to the battery since the battery have only red + and black- and the controller have 5 pins coming. I would be really thankful if you can help and send the a picture or explain how to connect the battery. Here is my mail: robotiger@gmail.com
该板装有大量电阻器。突出的是以下组件:
一个ATMEL MEGA 328P 电池管理 MCU
Ablic(原精工仪器)S-1142B33H-E6T2U 200 mA LDO 调节器
FL12.000 12 MHz 石英晶体振荡器
另一面,我们发现这些:
单n沟道沟槽MOSFET(x4)MDU1931 芯片
RS2M 整流器
interessant wäre ob das BMS beim Zellentausch abschaltet, oder diese Möglich ist, um z-Bsp Leistungsfähigere Zellen einzubauen, wie ich es unter www.ebike-workshop.com mache: 3500maH Samsung, dann hätte der Akku 7aH.
I made a tutorial for Changing a Custom Boot Logo for Qicycle :
Alguien sabría decirme donde se encuentra el sensor de temperatura en la placa bms? mi cargador no carga y creo que puede ser por un fallo entre la batería y el cargador por el dichoso sensor que le puede alertar de temperatura alta y deja de cargar y la luz del cargador se queda en rojo intermitente
Reasons for not charging the battery, It is a fault of the battery control board.
Normally the controller board will supply 100v+, but the faulty controller board will only supply 50v.
Does anyone know of any repair information without replacing the control board ?
thank you.
第二个重要的紧固件是可折叠手柄杆和主干。设计机制本身是很酷的,并且很容易拆开。
为了将前叉从铰链上取下,我们使用了不常见但必不可少的 10mm 内六角扳手,这是自行车维修的基本工具。
Could you please provide detailed dimensions of the fork?
The fork is wide enough to house a roller brake but they didn't fit a spacer. Also the axle is longer on the gear side as you can see in the picture on this guide. Another of those anti rotation washers was fitted on the inside of the fork but it's not very thick as you are supposed to add a lock washer under the nut. I think there should be a 5mm thick spacer between the hub and fork or a 3mm spacer if that non turn washer is inside of the fork. This factory setup likely puts the fork under strain until it gets broken.
大多数重要组件都住在电池针板上,我们发现了:
STMicroelectronics STM32100C8 微控制器,采用 ARM Cortex-M3 32位RISC内核
Microchip MCP2003 LIN J2602 收发器
Diodes Incorporated AS358M 低功耗双运算放大器
GH17M 晶体管
其余的覆盖板主要承载电容器和其它无源组件。
而且,这辆自行车被折叠,展开,完全拆解。
Nice job, I've just received one of these and am much happier with my purchase after learning about the inside of this sweet ride. Thanks!
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
128 件のコメント
My axiomi qicycle seat post keeps slipping down despite locking d 2 release clamps tightly. Caused a fall from d bike as d seat post slipped and hit d ground jamming d moving bike. How to tighten d 2 clamps to ensure no slippage especially cycling at a higher speed?
Thanks
The quick release clamps can be adjusted by using the bolt on the opposite side of the handle and tightened by closing the handle. The QiCycle is constructed for max 100kg weight. You may also try cleaning the seat post for a better grip (maybe it got a little greasy during the assembly).
I am wondering if the two saddle clamps can be replaced. And if so where to find them? Help very much appreciated :).
The saddle clamps should be replaceable with standard quick release clamps of the correct size. Depending on the design the handle might not be curved like the original one and therefore stand off a little bit.
Thank you for all the pictures. Unfortunately after a drop of the battery my taillight is not switching on anymore. Do you have detailed pictures of the disassembly of the taillight. Maybe it is only a connector that is loose... Thank you :)
Hi Montie, we don't have a separate guide for the back light yet. But to get it off, you need to grab it very tight and turn it counter-clockwise. The rest can be seen on the pictures in step 16 (four screws and the cables inside).
Hi Tobias, thanks for the fast reply. I know how to get to the connectors (thanks to your good illustration) but I need to get *into* the light because the connectors which are visible seem to be okay. Obviously I have to peel the red plastic off which is not clipped but sealed. The back (black part) of the light is one single plastic part if I see this right. Any further help would be nice. Should I use a knife? I don"t want to destroy anything...
Hi Montie, getting into the light itself without "destroying" it looks quite impossible I guess (we haven't tried it). The light looks as if it is sealed from both sides, front and back.
Hi!
My Charger seems to be dead. Even LED Indicator wont light up and it doesnt charge the bike. Do u have any advice or guide to open it up, or to work the batteryside connector onto another fitting charger?!
Thx
Hi Andreas, unfortunately we haven’t torn down the charger itself. Charging the battery via other means sounds like an experiment I would not recommend unless you know what you are doing.
Same with the case you are experiencing, is it now resolved? If so, I would like to get feedback on the issue from you. Thank you
There is a firmware update. It came automatically to me via the app. I mean I was asked within the app whether I wanted to upgrade the firmware that would lead to 25km/h.
Just FYI: firmware update seems to be possible only by using an Android device, not iOS.
I didn’t get any update firmware . what’s the last software version indicated in bicycle info in the app?
What does the Max speed mean?
If I'm pedaling quicker than 20km/h then the engine will not help me to reach 30?
Is there mode how can I ride 20km/h without pedaling?
Hi,
I tried to upgrade the Qicycle but it never ask me to upgrade the firmware in the app.
Could you say me which app we have to use ?
- https://play.google.com/store/apps/detai...
I tried with iphone too but it don’t work.
The version of the driving computer is : 1.6
Thx for your help.
Janoyolo -
Hello,
I just get this bike and I’m very happy with the quality of the model! Your tutorial is great and very clear, I will not hesitate to consult it if needed.
I have one question for you :
I’m 1,85m tall and I have to put the seat at its maximum position in height but that’s fine. The problem comes from the handle which is a bit low.
Do you know if it could be replaced by a foldable adjustable handlebar ? I’ve seen some on the market, and it would solve this issue.
Thanks for your amazing work.
Léo
Yes, it is possible, something like https://www.aliexpress.com/item/Aluminum...
Although the original stem has much better quality, so I ended up just adding this adapter to make the stem longer: https://www.amazon.com/TranzX-Alloy-Twin...
I have another important concern :
My electric motor is not working on my Qicycle.
When I use the different modes with the pushbutton, I’m not feeling any help from the assistance of the motor. The battery works properly, as well as the on-board computer that displays correctly : the battery level, the current speed, the power in Watt and the assistant mode.
The application shows the message : "One issue found : please check the motor line on the left of the front wheel”
I don’t know how to proceed to fix this. Can you help ?
Thank you
You may want to check the cable on the left hand side of the fork if it is connected properly (see second picture in step 11).
Regarding the height problem in your other comment I’m sorry to tell you that the bike is designed for people under 170cm. The seat post and handle bar post are non-standard components and don’t look like they can be replaced with longer versions.
This is not true, there are 3 options:
1) Replace the stem with telescopic one
2) Add the stem adapter https://www.amazon.com/TranzX-Alloy-Twin...
3) Replace the handlebar with curved one
у меня такая же проблема. кажется, что корпус является монолитным. это не так, как там покрыть возможные отвинтите.
The lid sits very tight. Try to get a grip through the three holes (for example with two allen wrenches) and turn counterclockwise. (Caution: the lids edge is very sharp)
What did you use to open the lid Tobi?
Are you using three allen wrench?
I used two allen wrenches (short part in the holes long part along the axis) and used the axis as pivot point.
Is there a way to buy a battery pack for this bike ? I need one desperately …
yes, through Aliexpress.
Or you can check out some of the mods to the battery that other owners (Youtube and Google) have done to change the battery unit. This will obviously void any warranty.
Jay -
La bici mi é arrivata con il display del computer di bordo scheggiato,infranto il display una volta acceso non é leggibile.
Come posso ovviare a questo? È sostituibile con un nuovo display?Dove posso trovarlo?
Grazie
Aliexpress…. 65€ circa!
The chain jumped down while I went uphill and only low engine support. How can I avoid this in the future?
Hi Jürgen, check the spring on the rear chain stretcher (see step 5). This should provide enough tension for the chain to not jump.
Hello,
What kind of axel and nuts does the front fork have ?
Is it M10 nuts ?
Thank you
Hi Mourey, I used a size 19 wrench, so its probably M12.
hi! great teardown! do you know the dimensions and weight of the batterypack? i'm planning to buy the bike in china and then send the pack in mail, since its not allowed to take the battery in your suitcase or carry-on in airplane.
Hi maurits, the battery pack itself is 46 x 7 x 7 cm (±0.5cm ;) ), weight is 1.46 kg.
Thanks! If its not too much trouble, do you know the size of the bike when folded and the saddle removed? To See if i can fit it in a suitcase without completely taking it apart.
Spiegazione al di sopra di ogni aspettativa. Una pecca, manca la spiegazione su come installare la lingua inglese essendo tutto in cinese.
. Dolcclod - 返信
Dai un’occhiata a questa Playlist.
30 min ed avrai il display in Italiano!!
Michele -
help: I update the firmware with android and now the qicycle go fast to 26 km/h, but the led light rear don’t works more!, instead before it’s ok, also the computer on board don’t read the status of the battery, plase help me!! also other peaple have the same problem…
Hi everyone,
Did anybody find the right antitheft combination for the QiCycle ?
I’m thinking about the Kryptonite NY M18-WL + some Hexlox to secure the saddle, handlebar and wheels. But as I’m still waiting for the bike to be delivered, I can’t really figure out if Hexlox can be used on these wheels.
Anybody tried or has other ideas ?
Thx !
Léa Gilezo - 返信
Hi,
Please can someone help me with the gears? I received my bike on the 28th of this month and I have successfully upgraded to latest firmware. The problem I am having is on the 2nd gear when i pedal it feels like it is skipping, it is not pedalling smoothly. 1st and 3rd gear seem fine and don’t skip.
Any ideas how i can fix this? I notice the yellow dot in the nexus gear is not in the correct lines.
Thanks Az
This is because you have folded the bike in 2nd or 3rd gear, and pulled the gear cable, you need to fold it ONLY in 1st gear.
To fix it now you have to follow this procedure:
Hallo,
mein Qicyle hat anscheinend leider einen defekt. Das Rad schaltet sich von selber aus obwohl der Akku noch 80% hat und am Akku selber noch 4 LEDs leuchten. Auch das Update konnte ich nicht aufspielen, es wurde mir von keiner App (ich hab so ziemlich alle Apps probiert) angeboten.
Hat einer ähnliche Probleme? Ich gehe davon aus, dass der Akku defekt ist. Bei Lieferung war er komplett leer, also keine Statu-LED am leuchten.
Beste Grüße, Christian
Hi Az this could help You
Hi Bobo,
Thanks for the video. I saw this same video earlier today and followed the same steps but I couldn’t get the yellow dot to align in the middle of the 2 lines as shown on the video.
None the less I turned the cable adjustment all the way in and even though the yellow dot isn’t in the middle of the 2 lines it fixed my issue :)
Thanks
Hi, I need to increase the speed of this bycycle, would you help me with the tutorial, the video. Thank you.
Dears, I just received my bike, the app on android proposed me the upgrade. Since then, The onboard computer shows my battery being empty, the red light doesn’t work anymore also the electric assistance doesn’t work. Any way to do a downgrade of the onboard computer? (as on the battery the 4 led lights are on when testing.)
Hi Vincent , take a look here >> http://en.miui.com/thread-710300-1-1.htm... <<
I solved same issue following the instruction of the user julferber ( see page 2 )
Be patient and good luck ;-)
Hi, i have Qicycle EF1 since october. The bike worked well since yesterday. Since yesterday, the bike has some issues that are a little bit annoying.
I think it may be that the speed meter is broken, so it does not detect that the bike is in motion. (posible issue of hub gear motor measuring speed?)
-Display don't show speed screen when I run with it (in 22km of my travel, only show this is screen 2 times only 10 seconds, and the display show 0 km/h, 0km, 0wat) But all time this screen doesn't appear. Only show battery screen, the same screen when you're stopped.
-The display tur off when I'm ridding, like when the bike is stop. 1 min for default setting. When I press a button when I'm reading, the screen wake up, like when the bike is stop.
- I can't change the power assistence, If i change the bike continue to 150%.
- In some cases, the bicycle offers less assistance and lowers the power alone, just a few seconds, without any reason. The engine continues, but with less power.
Thanks!
Correct link:
Probably not. Bike dimensions folded are: 450x1000x650 mm. See product page, under specifications.
Is there a way to remove the speed sensor or trick it to believe it’s going slower than it is?
I mean to increase the top speed past 25kmh which is still a little slow. Or a firmware hack?
hello: I just got the bike and my mother fell with the bike and she hit the screen. I do not know if it has arrived with defect or has been the blow on the screen! The problem is that suddenly the screen turns off and runs out of energy! Sometimes when it is turned off and the lights are on, the back light stays on for a few seconds when the screen is off, until it shuts off completely. I'm about to buy a screen! I could i check in some way that the screen is causing the bike to turn off?
Here is link to fix:
hello,
i have MC and BMS show 000-000-00 and i’ve lose electrical assistance !!
can not update MC and BMS with QiCycle app official or not :-(
Bobo -
Salve, sono Vincenzo
ho una qicycle, che negli ultimi giorni mi sta dando problemi, la sento più pesante ed il motore non mi sembra sia scattante come prima.
Da cosa può dipendere? io mi sono accorto di qualche anomalia al cambio, la marcia 3 non entra alla perfezione e la taratura in seconda risulta non corretta, il pallino giallo si trova fuori dalle due estremità di “set” può dipendere da questo? cmq cercando di settarla rimettendo il pallino al centro , ma quando provo a muovere il cavo di riferimento questo non si muove… che posso fare?
grazie a presto.
* Why has the control unit 5 pins? It labels plus and minus for the 42V so far so good but what is the e.g. Vlm pin for?
* Also the charging cable has 5 pins. Why is that? The battery has 10 cells in series so I guess it cant be for balancing reasons.
* Where can I find such a connector/socket for the control unit plug?
The reason for my questions are that I am planning to do a 42V battery pack by myself.
Hey Martin,
have you figured this out? I’m also interested in this.
IR Here -
Hi guys,
I am experiencing an issue that has been recorded from others as well in the past.
The motor has stopped working since a few days.
The story:
- I had an accident falling off the bike about a month or two ago and since then I have been experiencing problems with the electrical assistance.
- First symptom was that the motor would not work always
The problem here was that the cable attachment under the battery tube on the front (https://i.imgur.com/SQFFSUQ.png) connecting the motor, battery, Hall sensor etc. had been slightly removed because of the usage and the crash potentially. The problem was fixed after it was properly attached.
To get the motor to work again I had to completely stop the bike so the Watts would go back to 0 and then start again.
- I kind of got used to the above problem but then the motor would not work at all. The display works as usual (showing Battery, Speed & Watts ).
I opened the black cable from the motor as in the post below and found one of the three (the blue one) fat wires inside (out of 9 in total) cut. I then used one of those wire connectors https://i.ebayimg.com/images/g/HnoAAOSwG... to connect it back and did it successfully. After removing the cable all the way from the motor to the plug before the torque sensor I tested with a digital multimeter that there is conductive path from each pin of the plug leading to the torque sensor with one pin of the central plug (under the battery) and same between the pins of the plug leading to the motor and the central plug again. So, it seems that everything works correctly with the cable.
Doing the self-test within the app for the bike, I got notified that there is a problem with the front wheel and the left side of the cable . As mentioned previously everything has been plugged correctly and fixed the cables.
My only hypothesis is that either:
1. The torque sensor is not functioning properly (I will try cleaning it as per the link https://translate.google.com/translate?a...). I don’t think it is this having a problem though, cause the Watts displayed are in a normal range that the motor would normally work. Same for the speed therefore the problem must be in the motor
2. The motor has a problem. I have unscrewed the 3 lid screws but can’t open the motor at the moment and even then I wouldn’t know what is the problem and how to fix!
3. There is still a problem with the cable or plugs (eg not making proper contact)
What do you think might be the problem and what should I do next?
hello,
few days ago i bought an used Qicycle. The Bike totally has 12km. Outside it’s in a very good condition.
Now i recognized that the wattmeter still shows “0”. I am sure the motor doesn’t function. Now i need some help .
What I did :
-Flashed back original software now it is :
LINPic 003-013-000
MC 005-017-000 (25km/h)
BMS 018-024-023
Firmware 1.6.613
-Checked Akku -> Loading Okay, Lights Okay
-Checked all cable connections (motor left, controller, display, hall sensor)
-Checked intergrated cable if it is broken. All 16 cable contacts give a signal. I post the wiring of the cable for the community. With my plan you can check if the wiring is ok.
http://up.picr.de/33540863mf.jpg
what could i do now ? Buy a new motor, how could i check if it is broken ?
Buy a new controller ? Does this make sense, because all seems ok. The Qicycle Software says “bike is Ok”
Buy a new “Hall sensor”, don’t know if this could be the problem…maybe a expert could tell me.
If somebody help me to get a solution i would donate something.
harald
Dear Harald,
My integrated cable has more than one pin broken but I couldn’t figure out what wire to check as all 9 wires look intact in appearance. Please send me the wiring color code for pin numbers that are shown in your wring diagram.
Many thanks in advance.
phu dang -
Oh..sorry, at the Moment couldnt find it…
Harald -
There is a strong resistance on front wheel only when turning reverse (no resistace moving forward). Motor not working although computer provide all the data even the watt usage. Pls assist any feedback would be very much appreciated
Hi lousky007!
My bike has the same problem too. I tried unplugging the cable from the controller and the front wheel can be turned backwards without such resistance. I did the same procedure to the hall sensor but the prolem remains the same so a malfunctioned sensor could be ruled out. I guess the segment of cable that connects the front wheel motor to the controller may have some broken wire in it. This segment of cable is very tight so don’t turn the front wheel to the left until it stops as it is prone to failure if you overdo. I ordered a new cable and I am waiting for my delivery. Have you successfully fixed it yet? If yes, please tell me the right cause.
Thank you very much.
phu dang -
Where did you buy this cable?
Karim -
Hi Karim,
I am so sorry for late response. I bought the cable from Aliexpress. Just google it and the results suggest a variety of shops selling it. But at the moment the cable is not available any more. I think you should wait and check it on Aliexpress periodically. In the next five days I will give you the wiring color-pin information, DO NOT discard the cable, it’s the most repairable part once you idenfy the damaged wire(s). I will try get back to you soon. Have a good day!
phu dang -
@phu dang,
sorry i have no color code for the pin numbers, because i only did a measure of the cables. my wiring plan is quite simple you only have to check the numbers of the pins which are wired.
as i wrote above my problem is solved. First problem with the update was an incompatible android smartphone. Changed ist and the update was successful. Second problem was not the wiring, but the hall sensor. Changed it to a new one and evrything was fine.
If you habe broken pins on your cable why don’t you chnage the cable. It costs about 25$ and changing should not be a problem.
Thank you very much for your kind reply. The problem my bike is experiencing may be somewhat that relates to the front wheel motor, the controller, the hall sensor, the cable… I have ordered a new cable on Aliexpress and I am waiting for my delivery. But what if I can’t still fix it? I will try replacing with another part by ordering a new one until the problem is resolved. I will let you and everybody in the forum know the exact cause when i have sucessfully fixed it as a way of sharing experience.
Have a good day my friend.
phu dang -
hello phu dang,
best wishes for you to solve the problem. i understand that you are afraid of not finding a solution, for me it was the same. As i said it is easy to check the cable. take my wirking plan and a voltmeter. you can easy do a measure if there is cntact between the poles. As i read in other forums often the hall sensor was the problem. The motor or the platine/chip/controller is rarely the problem. The motor is verry robust. Are there any errors shown when you do checks with the app ? The app should show contact/wiring problems with the motor. In the other forum someone told me to change the hall sensor and he was right.
Harald -
Hello Harald,
I greatly appreciate your kind suggestions and your helpful information. Because at the moment the cable has not been delivered yet so I cannot do anything with my bike. I’m glad to hear that the motor is robust and it seems to immune to malfunction as this part is very expensive. Could you tell me the app you mentioned that can be employed to check problems relating to contacts/wiring with the motor?
Thank you very much and best regards.
phu dang -
Hello Phu Dang,
its the Original App from Mijia .Maybe it is only in Chinese Playstore. You have to sideload the APK, for example here.
https://www.apksum.com/download/com.velo...
The App cant check the motor or the wiring direct. But for me it was so that it showed no error. For other people it showed errors which mostly have to do with wiring in the front to direction of the Motor.
Harald -
Dear Harald,
Thank you very much for your help. I will try the app and let you know what it’s telling later.
Could you send me the address link to buy the torque sensor on aliexpress?
Best Regards.
phu dang -
Harald -
Hello Herald,
The item from the link is no longer available. I did google the torque sensor and the LCD monitor but I could not find any items that is available at the moment. OMG this time would be a tough one for me. Do you have another link for those items?
Best Regards
phu dang -
In this link First isahown Not available but if you choose delivery country (for me germany) i am able to put it in the basket. 97 items are available
Harald -
Dear Harald,
I picked Vietnam as the delivery country but the message ”sorry, the product is not available at the moment” kept popping up. I think the best thing I can do now is to wait for the cable assembly to arrive and then decide the next step to do. OMG this is a time-consuming task so I’d better stay calm and wait.
Thank you very much for your kind support.
phu dang -
hello jay,
hahaha i am not a technican for qicycle bikes i am a user as yourself. i think if you are good you could do anything with the bike. here is a video which shows the opposite of a throttle, a mod fro full power
https://www.youtube.com/watch?v=gqvqy6Ht...
Video only should show that everything is possible, but i don’t know how to do such mods.
Harald
Harald -
Hi, i have Qicycle EF1 since Feb-2017. The bike worked well since yesterday. Since last tow-day before, my bike front wheel inner tube bust. so i open the wheel bolt nut b4 i unplug hub motor wire,. after replace tube with Tyre, re-fix as well same. after test cycling motor not running… the bike has some issues that are a little bit annoying. the computer display motor speed meter show well battery also 100’/. whats a problem can solve me pls…. here Singapore so hard to find a repair shop…
The saddle clamps should be replaceable with standard quick release clamps of the correct size. Depending on the design the handle might not be curved like the original one and therefore stand off a little bit. https://apkroyal.com/app/six-pack-in-30-...
Très utile, merci beaucoup!
Isabelleni - 返信
Amazing post. I really need some help. The part that connects the seat to the top of the pole has broken on mine and I cannot find the part. I visited many bike stores here in the UK and cannot find a replacement. Also, where is the best place to get a new charger? thanks again
Gazzi Keny - 返信
Hi Gazzi Keny, maybe you’ll find some information here at the answer section: Where can I buy spare parts of Mijia QiCycle Folding Electric Bike?
Hi guys,
I bought this bike as used (the total Kms made by the previous owner was 320, so I consider the bike almost new), and I’m going to use it in order to reach my new work place that is at 55 minutes from my house, hopefully I’ll save a lot of money from transports, and I was wondering if this is actually reliable because I’m gonna do something like 30kms per day.
I’m currently waiting a new battery from aliexpress, in order to be able to cover more distance. Do you think that the Qicycle could be ok?
However I have one little problem: the plastic that holds the display to the handlebar was broken due to a problem during the shipping, and even if it holds now, because the previous owner fixed it with glue, I was considering to change that specific part, but I would like to keep the display because it works perfectly, even after I updated the firmware to the 25kmh version.
So basically it is possible to change only the plastic that holds the display, without changing the whole thing?
Thank you very much!
Matteo
Im having problem locking the magnets together phone folded, the magnet can't seem to hold is it a factory defect or are the magnets of the qicycle really weak, or if it an alignment problem. Thanks
thanks for this wonderful article
“Der Akku ist eine komplexe Baugruppe, was einen Ersatz zur puren Verschwendung macht, wenn einzelne Teile nicht mehr funktionieren. “
—Das stimmt, deshalb gibt es Akku Spezialisten wie mich (www.ebike-workshop.com) die hier auch nur die (verschlissenen) Zellen tauschen können. (natürlich inkl. Punktschweißen, Kapazitätstests, Funktionstests, optionale Leitungserhöhung durch moderne Hochleitungszellen von SAMSUNG usw..)
since changing the frontwheel tire severalproblems have developed with the motor.
1. the motor starts before pedaling begins.
2. the motor appears to be on continually, thus the available energy from the akku
is very rapidly reduced.
is a reset possible or any suggestions to deal with the problems ?
I have opened and reconnected the cable connection for the motor on the front fork
during the tire change.
the power for the bike was switched off during the repair.
Hei!
A have the same problem. I changed the tires and since then motor starts before pedaling begins and if I stop pedaling motor still runs.
Hello! The seatpost of my qicycle loosened and crashed into a stone, the bottom part bent and I can't straighten it Anyone know where to get a spare. Thank you
Take a look over here, maybe you’ll find some information in this answer section: Where can I buy spare parts of Mijia QiCycle Folding Electric Bike?
I found This page by searching for qicycle accident and need to share my experience. After buying it brand new and using it 5 times to go from home to the tennis court 1km from my house when I was ridding it the welds on the steering column between it and the handle bar cracked open and the handle bar detached completely from the steering column. I had several traumas on legs hands, head and shoulder and an acromic clavicular dislocation level 5. Now Im gonna have to do a surgery to fix my shoulder and as I imported this $@$* from another country there is no company I can sue in my country. I recommend you all to keep an eye on this welding and replace it with something safe or tou might not be as lucky as I was.
How to change Qicycle Boot Logo by Grimor:
After 3 years my bike starts to drive on it‘s own and powers up to 120 watt for 8 seconds after last pedal movement - which unit would you change first?
Hi all, I just bought a brand new qicycle but I noticed that when moving the front wheel in reverse there is a little resistance if moving slowly that disappear when moving faster. When spinning the front wheel normally there is no resistance at all. Do you think it is ok? Thanks in advance
Do you have teardown for the Qicycle EC1? (model: TDP02Z). My EC-1 won’t charge only after 1 time use. Can you help find out What the problem might be? Thanks.
Hello everyone, I’ve a Xiaomi Mi Qicycle bike, i used it for a few months but a day at some point the screen changed: doesn’t shows me the speed modes anymore and there is no electrical drive anymore. The mode is set one BO+ and i can’t change it. The only options on the display are SET, SUM and INFO. I checked the cables and it seems they are all in place and not damaged. Does anybody know what the problem can be? Somebody that had the same problem? thanks
Gab es hier eine Lösung ? Ich habe das gleiche Problem Mein Rad hat keine 300 km gelaufen
Is bms locking after disconnect from cells ?
A non-electronic question: Here with my EF1, the front steerer tube has a bent screw. I think the pull was a bit intense sometimes. Now the folding mechanism can’t be fixated properly anymore and the steerer tube folds ocasionally.
My question is: Where can I get a replacement screw? Does anybody know the specs what screw to look for?
I found one, by the way, in my local screw shop. No online options, only good old shop owners could help me out with the correct screw.
huedrant -
Hi,
Do you know the manufacturer name and P/N of the charger connector (the one you connect to the bike) ?? I bought a QiCycle charger but its connector does not fit my bike which is a XIAOMI one… Connectors are similar but not the same….
Hi thank for that very close look to the bike. I wonder what's the size or specs of bottom bracket. Mine makes too much noise I need to replace it.
Hello guys,
I bought this bicycle. At least I thought I bought this, but it turned out there is 2nd generation after 2020. I wanted to modify to full throttle but it has a torque sensor in the bottom bracket. Do you have any idea how can I manage a modification?
I received the bike for free but i have some issue :
· Battery won't charge anymore, The charger light stay green.
· monitor won't start
· Battery led blink 10 times only when i pushed the button when the charger is plugged.
· I tried the trick by reversing the front wheel, but the charger light still stay green
Then
· I've managed to dismount the battery and charge it to a benchtop power supply at the maximum it can do : 30v and 1.5a ( limits of the benchtop )
· Battery giving me 19v before charging (Black & white wire ) and 21v (black and Red wire)
Results
Still impossible to charge the battery ( voltage is too low i think ) but i'll try again to reverse the front wheel with an Electric drill.
Actually there is still all the led blinking 10 times when and without Charger this time.
Do you think there is any hope to revive the bloc? There is any chance that the BMS is broken due to a direct charge ?
Maybe should i charge each battery individually ?
I ran into a car on my 1 year old bike (their fault). Result: bent fork, damaged head pole and broken front rim. No shop in Germany will fix it for me because they are not the standard parts - as noted here in this page!
If you need parts and you are in Germany - check out Kleinanzeigen, maybe I can help you get back running!
Hello i got the qicycle second hand, but here in Norway its got max speed of 20km, but i want it to go max by the law and that is 25km. i need to change the dashboard to a chinese one because the international version dont have bluetooth, i was hoping that you had a guide on how to remove the part, but i couldent find one, where do i unplug the dashboard?
Hello, do you know how to fix Qicycle that turns off randomly? It was turning off randomly while I was riding it but now it won’t turn on at all. Any help appreciated
Für Europa mit nur 75kg Traglast nicht zu verkaufen.
Gerhard Hallermayer - 返信
One question please ananda hub is rated at 30 nm torque while xiaomi says only 7.3nm …any suggestions?
rott74 - 返信
Se non si accende il computer di bordo ma la batteria è carica cosa si fa?
pamarotta - 返信
