对于这样一款智能电池,看起来大部分的大脑可能都依赖于iPhone上的软件。我们只发现里面一些基本的ICS:
NXP nx20p3负荷开关,也发现闪电USB电缆
NXP 1608a1充电IC
智能电池修复2出10(10是最容易修复):
非专有的T3 Torx螺钉使维修更方便,但被有很强的粘合纤维衬垫覆盖。
电池更换是可能的,但可能会破坏超细纤维衬垫。
唯一可以修复的部分就是更换电池,但是却被用胶水牢牢固定住
在不破坏设备得情况下,其他的维修是不可能的。
以下の翻訳者の皆さんにお礼を申し上げます:
92%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
28 件のコメント
So it's a workaround for all the dead phones that can't charge because of U2 chip failure from non-Apple charger usage. Make and sell an external U2 chip-on-a-backpack to provide your phone with an externally chargeable battery. Way to spin that one Apple. Nice save.
The phone still uses it's own charging IC, this IC is most likely only used for charging the battery in the case and feeding battery charge data (from the Ti chip in the base of the battery) back via the lightning port.
Just one simple question. Dose this set of chips work for all lightning iDevices?
I know the case size does't fit the iPhone 6/6S Plus and iPhone 5/5S. However, you guys have it teared down. At this stage, certainly you can give it a shot for other iDevices. Why test this? Well, if this set of chip works with other iDevices, we may able to see Apple or third party Battery Case soon. Since those cases on the market is not able to show the battery usage in the notification centre yet.
no, it dont work
sacor22 -
I dont understand why Apple never added a better speaker into the bottom of the case.
So does it pass through the 3V of the LiPo or does it (inefficently) go 3V --> 5V then make the phone go 5V --> 3V like every other iPhone external battery?
I would think the 3V (3.6-3.7) is a limit set by the battery technology. Why if it's gonna charge over the lightning contact it needs to be transformed to 5V. I'm afraid that the current phone designs will not allow for any other way.
Maye though one could go for 6V with dual battery cells, and then bring it down to 5V.
But that would more than double the risk for a faulty battery, and complicate the charging circuits that would need to balance the cells, and make sure it would not charge if one cell is broke. If balancing would fail the result could be fire and explosion.
So just the risk would have Apple not to opt for a 2 cell version.
T Est -
Rather than peeling the case apart, it looks like you could place a template over this case and cut through the backing only where needed to remove the plate. That would cause virtually no functional damage.
Why would you want to remove the plate?
If the 'smarts' in this case are actually in the phone -that would suggest the features which set this case apart could be available for any battery case.
The only thing that's different is the iphone has some way of 'knowing' that this case is an Apple one.
I'm sure someone can make an app, possibly it would have to be a jailbreak tweak, that makes the iphone recognize all battery cases, not just the official apple one and we'd have the same 'smart' features for any case.
I wonder since the Iphone 7 doesn't have a headphone jack.. Might they put a DAC into the bottom to restore it? Since they iPhone 7 is a bit thinner too, it might have less battery capacity. Though they did say they were able to "add" some more battery capacity because of the removed headphone jack, and the A10 (might) use less power. That would be a win-win for people who want more battery life, don't "mind the bump", and grumble about the lost headphone jack. But it might be harder to sell AirPods. Especially if we have a “AirpodFallingOut-gate”.
And defeats the purpose of removing it to begin with to force people to "move on". And get researchers to figure out how to make a lossless Bluetooth codec that can reliably synchronize with video and remove (most of) the "buffering time" when the connection drops out. Maybe go lossy for a bit, continue real-time audio, and re-build the buffer at the same time. I don't know much about codecs, so that idea might be completely off-base.
my phone case got wet what can i do
Nick Elias - 返信
Dry it with a towel, use a vacuum cleaner to suck all the water out of the openings then put it in rice for about 5 or 6 days.
Where could I find that battery? Looks like if I was just replacing that battery it wouldnt be very difficult, wouldnt damage much of anything, once you peel that felt off, it wouldnt look the prettiest after re-attaching but thats all behind the phone out of site anyway. Anyone/>?
If you use hot air to warm the whole case up (like how samsung use a small low temp oven for their phones) the felt should come off in one piece and stick back like new (warm it back up to reseal).
I am looking to add a D ring into the corners of the case next to the headphone jack and the speakerphone to make this case into a purse. Is there anything in the corners that I would compromise?
I’m wondering if I can drill a hole in the headphone jack to make it a bit larger and fit my new headphones. Does anyone know if this would destroy the device?
What are the dimension for the actually battery?
Does anyone know any links to batteries that would fit in the charging case? For iPhone 7 plz
I just teared down my smart battery case and i didn’t have to cut the bottom part of. You just have to remove the glue form the cornes and push with a small screwdriver the female connector. I didn’t have to destroy the device like you said.
Mine went to the swimming pool and my friend(the one that pushed me into) tried to removed the cover and broken the cover lighting connector i can find a place to buy just the connector.
Its was very useful! So sad!
Hi, my case has stopped charging, the phone picks up the case but there is only a 1/100 chance of the case charging by replugging the plug. Do you have any clues on why? Or how to fix it?
Is there a place that I can send mine in for repair?
