はじめに
任天堂の左側Joy-Conコントローラーの初期ロットのいくつかは、同期の問題で悪名高いものがあります。これはちょっとした設計上の欠陥によるもので、家にある古いパッケージの中によくある導電性フォームの小片で改善できます!
必要な工具と部品
ビデオインストラクション
デバイスの再組み立ては、この修理ガイドを逆の順番に従って作業を進めてください。
12 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
7件のガイドコメント
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - 返信 共有
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - 返信 共有
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - 返信 共有
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - 返信 共有
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - 返信 共有
