在正式开始前,我们先复习一下手机特性。
5.5英寸 IPS屏 1920*1080分辨率
1300百万2.0光圈双闪光灯后置摄像头。前置500万像素摄像头。
高通骁龙801 2.5Ghz四核摄像头
3Gb LPDDR3 1866MHz 运行内存
64GB eMMC 5.0 存储空间(16GB可选)
802.11b/g/n/ac Wi-Fi, 蓝牙 4.0, USB OTG, GPS/GLONASS, NFC
令人印象深刻的硬件,可以肯定 - 但这是一个拆卸,而HTC one给我们留下了一点受到晚期的创伤。 这里希望“Plus”代表“比友商的手机更可修”
移下了后壳,就是这样。 第一瞥就可以看到嵌入式可充电3100 mAh LiPo电池。
乍一看,这个似乎比其他人似乎有一个更高,更合宜的电池。
手机后壳就是黄金派对。
3条金天线加上NFC天线贴片通过触点 来与机身相连
So, with the NFC antenna being part of the cover instead of the body/battery, is it safe to assume that a ferrous metal plate (used with a magnetic dock) wouldn't interfere with NFC use?
Went ahead and got one of the magnet docks. The metal plate behind the One's back cover (between the cover and the battery) does NOT interfere with NFC, or any other radio that I've tested.
Do we know which NFC chipset the 1+1 is using? I've heard different sources cite an NXP PN65T or a Broadcom. It matters a great deal as far as tag/card compatibility goes!
NXP. Source is this Chinese OnePlus One teardown: http://mobile.it168.com/tu/1616975.shtml
Translation: https://forums.oneplus.net/threads/ifixi...
Direct picture link with the NFC chip from NXP: http://image20.it168.com/picshow/900x675...
Peter -
what do this antennas belong to? there´s also the wifi antenna in that back cover?
我们捅了几次电池(就像这样),直到我们成功使用撬棒将其撬出。
唉! 看来我们也只能止步于此了,电池排线在被螺丝固定的壳下消失了。
I think i could replace my OPO's battery with OP2, what suggestions? Are the dimensions same? I'd like to add those 200mAh.
我们拉出内部保护盖子来接近电池连接器。 如果我们的计算正确,一加 一的电池即将被移除。
我们的撬棒执行必要的算术,3.8 V,3100 mAh LiPo电池是我们(和您的)进行检查。
与其2800mAh(Galaxy S5)和2600mAh(HTC One M8)竞争对手相比,它的表现很好。
对于那些读不懂中文的人,这款电池的最大充电电压为4.35 V,并有以下警告和注意事项(释义):
只能使用授权的充电器
充电时请保持通风
不要拆解,短路或穿刺
卸下主板需要断开多个连接器
尽可能小心,我们使用iFixit Tech Knife(通常称为K-nife)来从面板组件的侧面分离摇杆按钮。
Note small screw at bottom left ("little black dot" on lower left of mobo in main picture for this step). It must be removed to take out the mobo. This is one of 3 screws of a different size in the phone. The other two are under the little plugs in the speaker assembly, Step 15.
Also, note connector to the left of the rear-facing camera at top of mobo in this step. It has to be disconnected just like the connectors at bottom of mobo.
Thanks a lot for the guide, my phone has been diagnosed with water damage and had to change motherboard and small board, which I thought they did just that. But turns out my screen might have been switched/changed as well? Since my screen protector isn't here anymore compare to before I sent it for repair it's still attached.
My question is: Does the screen has to go too if the motherboard has been replaced? Or have I simply been scammed? Also, is it common that your internal memory will be wiped out?
Comments will be very much appreciated, thank you.
Replacing the motherboard will definitely wipe out the on-board storage. I can't see any reason why the display would need to be replaced, unless it also had water damage.
There is a white rectangle on the top left of the motherboard. Is this a water damage indicator as well? I send my phone to HandTec (official EU repair center for OPO) in order to fix the classic touch screen ghost issue, and they diagnosed my phone with water damage. In the image sent to me as a proof for water damage, this rectangle is redish, so i thought it might be just another water damage indicator.Can you please confirm that?Thanks for the great guide.
Yes. This white spot is a water damage indicator.
HelloI need a quick help phone broken screen when changed and open the back cover Motherboard did not pay attention to the three screws on the cover has been used to open the knife and when working on that removed copper tip of the motherboard and is located next to the entrance to the sound earphones there is a small white box and the bottom of a copper tip This side is moving away from the painting, please look at the picture 1 in step 10 you will see it
please help me !!!
最后,使用所有的连接器,主板是 -
Drat and double drat!这个主板背面有一个最后一个天线连接器。
Now I see the SIM card reader on the motherboard. I have a dire situation where one of the pins on the SIM adapter (the one on the motherboard, inside) was destroyed. This was due to my stupid attempt to insert a different SIM tray. Is it possible to replace the SIM adapter on the motherboard? Thanks
alltrivial - 返信
I'm in the same situation. My SIM card slot (including one or two of the pins) is completely messed up, and I'm looking to replace it. Were you able to find a solution?
前置摄像头和后置摄像头均由Sunny Optical Technology设计。
后置摄像头标有P13N05A,前置摄像头标识为P5V35A。
在Project Tango中,我们也遇到了Sunny Optical Technology设计的相机模组。
根据一加 一规格页面的细节,1300万像素后置摄像头配有Sony Exmor IMX 214CMOS图像传感器。
P13N05A is a Sony sensor in a sunny module. Sunny is a Chinese company which uses Sony sensors. It has SONY IMX214 sensor in it.
Refer the below link for more info:
众和为一 由许多芯片构成的一体
三星K3QF7F70DM-QGCF 3GB LPDDR3 RAM; 高通骁龙801可能在分层下面
高通WCD9320音频编解码器
AGD2 2402 WX9DR(可能是陀螺仪)
8407 CEH 05KTJ
B02419
P0911 3193
我们很快就用完了拉丁语的口吻,但芯片呢?还没接近呢!背面包含:
东芝THGBMBG9D8KBAIG eMMC 5.0 64 GB机载存储
Skyworks SKY77629-21功率放大器模块
高通WCN3680 802.11ac / FM / BT 4.0组合芯片
高通WTR1625L射频收发器
SkyworksSKY85709WLAN前端模块
Synaptics S3508A触摸屏控制器
Hello
Is it possible (eMMC 5.0 16GB) changed to (eMMC 5.0 64 GB) ??? , Or more than 128?
移除USB端口是足够容易的,但它似乎被困在中框的插槽下。
但不是完全的被困住! 我们以为是一堵墙,实际上是一条剥离的皮带,将其剥离。
哦,不,这个小电缆分支是在中框下面的。 我们永远不会让子板出来!!!等一会儿 ,没关系。
在另一个令人兴奋的剧情中,这个神秘的电缆从它的框架缝隙中弹出。
Ripped out a cable on the opposite side of the motherboard connector cable detatching the daughterboard while doing this step. No idea what it is.
Sorry to hear that, Austin! We try to prevent damage by labeling teardowns with this banner “This teardown is not a repair guide. To repair your OnePlus One, use our ++service manual++.” Check out the user-created guides in the manual to see more repair detail.
现在女儿板终于自由由由了。
这个子板是各种组件的永远的家,包括振动器和主麦克风。
子板底部有三个LED用于前面板组件电容按钮。 LED适配到显示屏底部的导光板。
This daughterboard is home to... the vibrator. What a naughty daughter.
在移除显示屏之前,我们先移除超级棒的听筒。
以下是技术规格:E3JE1HF
现在是完全不同的东西了,是iOpener的时间了!
That white rectangle where the headphone jack was is a liquid damage indicator. It also appears that they left a hole in the headphone jack purely to allow water into the main circuitry via that LDI...
And it allows it to lift the backcover with the headphone jack.
Oneplus shows this technique in their videos, e.g. the one showing how to swap the original cover to use their bamboo cover.
The earpiece on the picture is upside down !
Yes. The photo shows the speaker upside-down. But its not possible to mount it that way.
I think it is IMPORTANT to mention the following:
The speaker is stuck with some adhesive.
By trying to lift it up it is very easy to destroy this fragile component.
The problem is, the metal frame of the speaker is stuck by an adhesive sticker. And by lifting the black plastic, the two parts break up! If your are unlucky the super thin copper wire breaks and the speaker is dead.
So please. Lift the speaker underneath the metal frame which is hardly visible.
And also take care not to perforate the membrane.
So it is necessary to be very gently or to buy a new speaker
The black thermally conductive adhesive transfer tape, and the copper sheet that you can see on the first picture of step 19 hasn't been removed in this teardown, which I can understand since it's just impossible to remove without tearing the whole thing.
If you want to replace your midframe, though, you need to have this on the new bezel.
My trouble is I've searched the web without being able to find where to buy this thermally conductive adhesive transfer tape. So if any of you guys could drop me a hint ...
kedemferre - 返信
Copper sheet sticker acts as heat sink but there is only a small piece of it. In htc and Samsung phones it is wisely used.
I wondering what function of the little plastic peace on the right of the connector an above the ear piece is. I bought a second hand oneplus one and this peace seems to be missing. Because the screen was faulty I purchase a replacement screen and some great tools on Ifix to replace it. Replacing went fine but my screen has an horizontal band around the middle where it doesn't pick up touches. Very annoying! I've read there are problems with grounding and I'm wondering if this is missing peace is not the reason for my problems. I'm trying to find this part but it seems to impossible to find. Any help is welcome - confirm the use of the plastic part and where to buy it. Thanks.
dank meme lol
Can you recommend a certain type of glue?
I need to buy some for the reassembly.
Can anyone suggest a glue to use for reassembling the screen?
PJ Blank how did it go? I bought a new frame also and it came with adhesive that's shaped like the phone but it does not have the cut out for the screen's flex cable however it has some cut outs in it I'm just not sure what to do
someone could tell is possible separate the scanner glass lcd?
As anyone ever saw a video or knows how to "de-fuse" the Digitizer from the LCD? I found a store that only sells the glass/digitizer for 50€ and was really tempted to buy it (instead of the whole piece for 100€). In this website they say that they will send a video explaining how to do it but apart from a video I saw on XDA about the same procedure on a Galaxy S2 I never found out anything similar for the OPO.
OnePlus One可修性评分:5分(10最容易修复)。
没有专有的螺丝,只有一个螺丝头类型降低维修工具的成本。
相当模块化的组件将允许更便宜的更换零件。
在电池和几根电缆上使用轻微的粘合剂。
由于连接器被困在塑料面板和几个螺丝下,所以电池更需要更换。
LCD和数字化仪玻璃熔合在一起,必须作为单个部件更换,并且它们需要热量才能从中间架上移除。
i need to replace the lcd and the digitizer.. Can you assist me with the steps tha follow after removing the back cover.. and removing the visible screws is it possible to directlyu dettach the display?
and once i remove my display how do i attach a new one?
Help would be highly appreciated!
From my own teardown of the phone (and waiting on replacement display now), it looks like you need to do the complete teardown to change the display. My display was shattered; I used Scotch tape on the screen front to keep glass shards from getting everywhere. I used a heat gun to separate the display (and digitizer, which are one unit) from the frame. Will probably come back here to let you know how it goes.
PJ Blank -
where i can buy daughterboard with microphone ???
my microphone dead and the phone is useless now ...
Hi, My OPO has lost it's display due to water damage and needs to change the Motherboard. Can anyone help me with finding the place to buy it in India???
The Galaxy S5 got a 5/10, and is significantly harder to repair. I'd honestly slot the OPO alongside phones like the Nexus 5 and Galaxy sIII. Everything is one size screwdriver and the battery requires the same exact level of disassembly as the Nexus 5. I'd say it deserves a high 7 if not a solid 8--definitely not a 5.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Leon赵国鑫さんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
50 件のコメント
Hey guys, nice teardown. I'm guessing you probably already gave out your spare invites to your fellow workmates or friends but if you haven't I'd be eternally grateful for one.
Are you kidding me with this?
Haha some ppl really can't hold there s**t together
I bought 2 OPOs (sold one to a client, kept the other), both over a month ago, and have not received any invites. The invites I bought were $ 23.00 and $ 9.00, respectively, but now they seem to be in VERY short supply, and are going for bigger bucks. Not sure what's up with that!
PJ Blank -
Thank you. I was really waiting for this. OnePlus said they made the battery unremoveable to make the phone thinner, because they don't have to cover up the cables underneath.
That being said, do you think it's possible we will see a battery hack kit appearing on eBay? One that has a battery connector extender that extends to connector pins in the battery compartment and then a matching battery that can just be popped out?
Luckily, the OPO seems to have commendably long battery life, and many drugstores and convenience stores sell lithium packs with USB connectors for $ 10-$20 or so that just plug into any smartphone for extra power. I know, maybe unwieldy and not pretty, but functional!
PJ Blank -
How many wifi antenna's are there in the OnePlus One?
What's interesting is that that those Yamaha speakers have been called JBLs in quite a few other articles (like this one: http://www.phonearena.com/news/The-OnePl...). Do you think that OP is hyping the product inaccurately, that different OPOs carry different speakers, or that well-meaning collaborators are reporting specs based on deals that they're not aware never went through?
aliexpress, for one, and ebay, for two.
PJ Blank -
get new one. hah::))http://www.ghdeal.fr/oneplus-one-smartph...
pat -
Hmmm. I added what I believed to be important edits to this teardown, such as describing the two types of screws in the phone, mentioning some additional care when disassembling, removing a screw not mentioned in Step 10, and such. This appears to have been completely disregarded, and there is no longer a link to view unverified comments as of this time (and no notice to me, as if I was trying to do something malicious). I urge all who disassemble the OPO to be extra-wary of a few "gotchas". Guess I'll add them as comments to the steps instead.
Good luck.
La verdad es el mejor teléfono. Vale mucho mas que un experia o un galaxia y cuesta mucho menos. Es el autentico rompedor de gigantes, están revolucionando el mundo
Why does this get a lower rating than the Nexus 6? The nexus got a 7 and this got a 5.
In the Nexus 6 guide the back cover was glued on, this isn't the case with the OPO
In the Nexus 6 there were something like 22 screws holding the back on, theres far few with the OPO
With the Nexus 6 you complained that many parts weren't detachable like the MicroUSB port, in this phone many more components are attached via removable ribbon cables.
Looks like your fine work has been leeched here (and the text mangled in places):
Hello just replaced the display but unfortunately the mic and speaker do not work... Any Idears what to check?
Hello, I'm looking to buy the lcd+digitizer+midframe assembly for the supposed sake of convenience. What would be the differences compared to what's shown in this specific teardown? Would it require a lot less steps or would I still have to go through the steps shown here? Thank you!
Dice Craps - 返信
I would really like to know why this is still only focusing on *how* to disassemble, as opposed to the logical evolution of intent, which is to educate people about the hardware contents of their devices; the tear-down being a means to "dig in".
My concern are three "ghost" chips in the A0001, specifically:
8407 CEH 05KTJ
B02419
P0911 3193
Also, in addition to the two Qualcomm chips, it would be valuable to point out the GPS and NFC antennas.
Maybe it is just me, but I have always found security value in these tear-downs.
Thanks though, for what it is,
Spencer
funkyfunky - 返信
Is there any way that we can relocate one of the speakers to the opposite end so that we have sound coming from both sides?
schubeir
subirdutta - 返信
I think the copper sheets provide good heat transmission and it is found used in htc phones quite widely but i am worried about OnePlus phones, thermal management is poor though.
I'm replacing my volume controls and notice you guys did not de-solder the volume or power buttons, how is that done? what does it look like without solder on it. I've de-soldered mine and I see that there are three rectangles where the solder was, but i don't see underside contacts, did I rip them off an accident?
There are no solder underneath the boards. So you can just solder it on the upside of the board. You did not rip them off.
Beatz -
do you repair oneplus one mother board
buzzar1987 - 返信
Auto repair....Ok
Does anyone have a schematic diagram for OnePlus One?
I broke my screen, replaced it, but also broke charger connection pins, so I need to braze it to alternative ones...
THANK YOU!!!
i have a oneplus one 16gb which is having motherboard problem and oneplus 64 gb with a cracked screen. can i interchange or are the connectors different. pls reply arunoriental@outlook.com
They're most likely the same! Give it a try and let us know how it goes.
Thank you for this, I just replaced my screen AND before my screen broke, my phone was acting slugish... So, after I had the screen put in, I ended up clearing the cache and dalvik. Now, I am experiencing the "Sleep of Death" syndrome where everything works fine until it falls asleep for more than 20? seconds. Then, when I press the power button to wake it, it just is a black screen. The phone seems to be working, as when I go to wake it it vibrates and still rings when I get a call, but the screen is black. I have deleted everything and tried two different roms and also reverted an old backup all with the same result. My question to you is, do you think that maybe there may be a connection or something that I missed while putting the phone back together, or could it be the screen itself maybe? I feel like I should have ruled out any software issues, and the same issue was happening while in recovery. Any clues would be awesome. Thanks.
My oneplus one phone battery status stuck at 50%. Charged for 7-8 hours many times but the problem persist. Have changed the usb port flex cable and battery but the problem is same. Please guide me what may be the problem. Sorry for my bad english.
That screen is a nightmare to remove when shattered and putting a new one in on my Oneplus One had some issue with the middle frame and lifting underneath on one part. Replacement LCDs are crap and breaks easily. I prefer buying it now with the frame included less adhesive to worry about.
Hi guys.
While openning the cover i broke this pin and now i have poor wifi signal and disconnecting bluetooth. Can i replace it, soldering some iron into it and it will be back to normal?
Example img:
[url]http://prntscr.com/is46n2[/url]
Personal img:
[url]http://prntscr.com/is4b2s[/url]
HELP PLS!
Same problem here, =(
Did you fix it?
123Mar -
Git the same Problem.
It seems like even the Ifixit Guy who opened the Phone destroyed one connector.
https://d3nevzfk7ii3be.cloudfront.net/ig...
If u look closely at the connectors one can see, that one pin is already missing…
Btw: How did u guys repaired ur Wifi/Bluetooth?
Ro _Bat -
Salve
ho un problema… ho sostituito lo schermo e quando lo accendo appare il logo e poi più niente ma il telefono rimane acceso… cosa può essere?
I used this guide to change my LCD screen, it worked perfectly and took me 2 hours.
Thank you, it’s awesome! Hélène.
Hello people, because of some issue headphone was not fitting in my headphone jack. Then I inserted a pin inside headphone jack. I hammered for a long time and I unfortunately broken something inside part of my phone and my WiFi stops working. ( There is only range for my WiFi when I put it near modem - range within 1m distance ) later I opened my cellphone and change WiFi wire which is near battery ( but I think it was not correct solution ) can somebody tell me what I need to change ? near headphone jack, is there any WLAN related part ?
Thanks for the article!
Be very careful while removing the battery! Without reading this instruction I’ve done this by my own and the battery has broken. Fire came out. This was very dangerous. So please smoothly peel off the sticky tape.
A new battery working fine. Replacing a missed SIM tray was also not a problem.
Charging my phone is difficult because the USB port has a slack joint. So I will replace the USB port soon.
I’ve installed Lineage OS 16.0 which is based on Android 9.0.0 (Pie). It works great. See https://wiki.lineageos.org/devices/bacon
The guy who translated this page to chinese s literally copy-pasted from google translator.
