はじめに
ダウンジャケットが破れてしまったら、ピローファイトで羽毛まみれになったかのようになるかもしれません。破れ目から羽毛が出てくるのを防ぎ、破れが大きくならないように補修テープを貼ります。補修テープは優れた応急処置で、しばらく効果もありますが、最終的にはきちんと補修することをお薦めします。ダウンジャケットの補修の詳細につきましては、バッフルの修理方法をご覧ください。
交換パーツやさらなるサポートが必要な場合はパタゴニアカスタマーサービスにまでご連絡ください。
必要な工具と部品
25 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
10 件のコメント
I have now put four or five tenacious tape patches on my son's down sweater (9 year old are tough in VT). But now it is very dirty. Can I wash it like I would if it didn't have the tenacious tape - or do i need to do something different?
Hi Hylah, Yes you can wash your jacket and if the patches are starting to peel a little after 7 years you have some options. 1) Contact Patagonia Burlington Store and ask for some more patches, each store has a variety of patches, zipper sliders, Zipper pulls, snaps, buttons to help with easy repairs. 2) Send it to us for Repair, you could take it to the store or start the process on-line . https://www.patagonia.com/returns.html
Holes are not warranty but due to wear and tear, we will repair it for you no problem. Our goal is to keep product in use as long as possible. After they have reached there end of life use, we can recycle it for you and then you can invest in another long lasting durable product. Please check out this link for additional questions. https://help.patagonia.com/s/article/Rep...
Hi Sheilaym 1, Everything we make can be washed, Cold water Low tumble dry. It's good to wash your shells every once in a while to remove dirt and oils.
I've found super glue works pretty well and doesn't show the down.
Have you seen this product? "'''fixmytear'''". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Apply it to both sides if you can for extra strength. Absolutely life saving tape.
Nooooonono. Send it to Patagonia! They will fix it for you or even replace it with something new.
You are welcome.
@debshalcrow Thanks for your comment, but these guides were made in conjunction with Patagonia to help users. This guide can help patch a leak so you can get back outside and on with your adventure without having to wait 4-5 weeks for Patagonia’s repair team to return your jacket. Also, repairing something yourself adds personality and history to your jacket. There are fun shaped tape patches available, as well as a guide on how to do the full baffle sewing repair, to help make the repair easy to do. As Patagonia shares via Worn Wear, repaired and reused is better than new. https://wornwear.patagonia.com/
I have a Patagonia pullover windbreaker from 1991. Has a kangaroo style zipper pocket in the front. The pocket fabric is netting basically and has weakened creating a few holes over the years. In addition a dog tried to attack and bite my arm leaving a tear the size of a quarter on a sleeve. Is the Tenacious Tape the best way to go to repair these holes? If so, wondering if I’ll need to apply a patch on both sides of the fabrics?
Can you use this tape with a Patagonia fuzzy sweater?
