メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The replacement of the lens is needed if your videos are not coming out the way you want them to. If you notice that there are dirt or anything unusual on the lens it will ruin every video you take in the future, unless the lens is replaced.
パーツ
パーツは指定されていません。
  1. Push in the battery indicator.
    • Push in the battery indicator.
  2. Slide the battery out of the slot.
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Use the Phillips #0 screwdriver to remove the two 5mm screws. Use the Phillips #0 screwdriver to remove the two 5mm screws. Use the Phillips #0 screwdriver to remove the three 5mm screws.
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use the plastic opening tool to loosen the plastic case of the camcorder. Use the plastic opening tool to loosen the plastic case of the camcorder. Use the plastic opening tool to loosen the plastic case of the camcorder.
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  6. Use your hands to remove the plastic case.
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  7. Use the Phillips #0 Screwdriver to remove the 5mm screw Use the Phillips #0 Screwdriver to remove the 5mm screw Use the Plastic Opening tools to unhook the highlighted area.
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  8. Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  9. Remove the lens and clean it if needed.
    • Remove the lens and clean it if needed.
終わりに
ある他の人がこのガイドを完成しました。
Keven
メンバー登録日: 2016年03月11日
739 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016人のメンバー
UMASSD-BOTVIN-S16S8G5
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 345
