はじめに
The replacement of the buttons are necessary if you are struggling to manage through your menus, or having trouble pressing the buttons in general.
必要な工具と部品
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
Remove the one side 5mm screw using a Philips #0 Screwdriver.
Remove the top buttons from the hook.
2 の人々がこのガイドを完成させました。
