メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The replacement of the buttons are necessary if you are struggling to manage through your menus, or having trouble pressing the buttons in general.
パーツ
パーツは指定されていません。
  1. Push in the battery indicator.
    • Push in the battery indicator.
  2. Slide the battery out of the slot.
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Use the Phillips #0 screwdriver to remove the two 5mm screws. Use the Phillips #0 screwdriver to remove the two 5mm screws. Use the Phillips #0 screwdriver to remove the three 5mm screws.
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use the plastic opening tool to loosen the plastic case of the camcorder. Use the plastic opening tool to loosen the plastic case of the camcorder. Use the plastic opening tool to loosen the plastic case of the camcorder.
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  6. Use your hands to remove the plastic case.
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  7. Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera. Remove the one side 5mm screw using a Philips #0 Screwdriver. Remove the top buttons from the hook.
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  8. Unplug the connected wire shown. Pull gently not to cause any damage.
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
終わりに
ある他の人がこのガイドを完成しました。
Keven
メンバー登録日: 2016年03月11日
739 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016人のメンバー
UMASSD-BOTVIN-S16S8G5
3 メンバー
6のガイドは作成済み
コメント1件
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 390
