はじめに
READ ME: This guide has been archived by the author due to the age of this guide, and the fact this 360 is no longer around. I will not be updating this guide further. I have moved on from this guide but I feel like this could still help someone so I am keeping it around.
Game stuck in your Xbox 360? Here's a way that may work to remove it, in lieu of voiding the warranty (if the console is still under warranty).
ツール
パーツ
パーツは必要ありません。
  1. Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
まとめ
17 の人々がこのガイドを完成させました。
Nick
メンバー登録日: 2009年11月10日
44,289 ポイント
35のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
279 メンバー
772のガイドは作成済み
will this work for elite 250 gug
duangphetv - 返信
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - 返信
統計データを表示:
過去 24時間: 5
過去 7 日: 21
過去 30 日: 95
今までの合計 29,336
