ビデオの概要
Note8这么大,让我们看看里面都装了什么东西:
6.3" Super AMOLED曲面显示屏,屏幕分辨率为2960 × 1440(521ppi)同时配备了康宁第五代大猩猩玻璃。
高通骁龙835处理器,同时配备了6GB 运行内存。
3300 mAh 电池
双摄像头,双OIS,主摄像头为1200 万像素广角镜头,ƒ/ 1.7光圈 副摄像头为1200万像素长焦镜头,光圈为ƒ/ 2.4。
64/128/256GB 可选内置存储空间。 支持最大256GB microSD卡扩展。
S Pen,USB-C 接口以及耳机接口
IP68 级防尘防水等级
Hey iFixit. Please, please share a high resolution version of the X-ray so that we can use it as a wallpaper. You used to do it for the iPhones.
この手順で使用する道具:iOpener$12.99
I prefer a metal opener to take the back glass off, needs to be careful on the fingerprint sensor arear, additionally, a tweezer will be helpful when reassemble the fingerprint sensor. please note that your new back cover needs to have the fingerprint adhesive on. most of the product did not have. i have get a LUVSS back glass from amazon which came with all OEM adhesive and full set tools, even a B6000 glue, best option to go for replacing the note 8 back glass
この手順で使用する道具:Mako Driver Kit - 64 Precision Bits$39.95
我们很高兴可以使用十字螺丝刀来将中框/NFC天线/PMA和Qi 无线充电线圈组合拆掉。
在移除组合中框后,我们移除了底部的扬声器组件,现在可以看见内部的所有硬件了。
这是对过去的电池难题的微妙改动,还是只是三星打算让内部看上去整齐?是时候该看看关于电池这一部分了。
Im beyond grateful for this tear-down, but I was wondering if you’ve kept anywhere, the exact measurements of where the wireless coils are located in the back of the wireless charging phones? I am using a special mount for my phone and want to make sure the wireless coil is as close to completely covered as possible, but can’t tell from these images where the coil resides exactly, in the phone. If that makes sense. Basically, I would just look for a measurement from the top and bottom of the phone, indicating the start and stop of the coil. If not possible, no worries.
Hey Brandon! We don’t have an easy way to get this info right now. I’d suggest looking at the X-ray image in step 2, zoom in such that it matches your real life phone, and presto! The bulls-eye looking circle is the charging coil, so you should have the approximate location in your phone. =)
Hi all! That guide it’s perfect, thanks for that.
I have a question: please, it’s possible to have a Note8 inside-front photo? Just like that one but back to front.
Thank you so much!
Can someone let me know if the vibrator motor is replaceable as After dropping mine on the corner the vibration has stopped.
与其他近期的三星手机一样,电池在一点点胶里散发着它的悲伤,但我们很快就会将它解救出来。
一点点的热就可以将胶水软化,但锂电池是易燃易爆物,这里我们用了不同的解决方案。
这是三星SDI制造的电池,容量下降到了12.71 Wh(3300 mAh 3.85 V)
与Note 7的13.48Wh相比少了6%,当然,容量越大火烧的就越旺。 配备着安全电池的粉丝版也仅有12.32Wh,所以在这一方面也算是一种提升吧。(当然了,假设它不会着火。)
It would be nice if you could add dimensions of every battery you tear out from devices.
What iris scanner is the Note 8 using?
Be very care while removing the mother board or you will make the same mistake i did. The put one single screw through the right corner. Just to the side and down ax little from the sim card
Jesse King - 返信
Same here - I broke off a piece of the board and now my wifi doesn’t work
davidwhang - 返信
让我们看看屏幕下提供强大能力的元件吧:
三星K3UH6H60AM-NGCJ 6GB LPDDR4X SDRAM位于高通骁龙835上。
三星KLUCG4J1ED-B0C1 64 GB UFS闪存
高通WCD9341 Aqstic音频编解码器
Skyworks 78160-11功率放大模块
安华高AFEM-9066功率放大模块
Wacom W9018触摸控制IC
hello bro note8 n950f sound ic location place send me diagram my mail ahussain55807@gmail.com
Hello. You can details 3 Chips near ic . N950U
Contact. touchryna1@gmail.com
touch ryna - 返信
please guide me! Where ‘s the Iris IC?
Hi. My phone is broken. Can I remove 64 GB di memoria flash UFS Samsung KLUCG4J1ED-B0C1 and move to another device or try to read data inside with any kind of instrument, connector, device? How can I recover my data? Thanks a lot
what is different board color green and iphone board black color ? same quality or not ?
eastmail90 - 返信
board color can be customized,has nothing to do with quality,related to cost and beauty
zhaoqian -
where camera ic
Waqar Khan - 返信
Note8的OLED面板已经很受欢迎,有很多优点,但我们更关心如何将它拆下来。
答案是:加热以及你所有的撬片。
红框所示为三星 S6SY661X (应该是触摸控制)
Does the display still work? Maybe glass only is an option if you can get it out.
Not sure if we think about the same thing, but the two connectors in the image above fits the rear side of the motherboard (the first image is step 6 shows this reasonably clearly) so the back panel must come off to disconnect those.
希望你一路以来记了笔记,因为这个Note (手机)坏了。
再一次,大大的感谢给 Creative Electron,将我们的拆解工作带入到新的维度之中。
是时候揭露可维修度分数了。
Photos are blurry. Microphones are not covered, water resistance isn't covered. LACKING details.
Funva Oped - 返信
Lacking clear high res photos. Lacking info on mics. Lacking info on ware resistant implementation around each port and sealing phone case. Lacking many details of internal compartments. Barely adequate. High level vagueness compared to what's needed to service it.
Funva Oped - 返信
以下の翻訳者の皆さんにお礼を申し上げます:
60%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
53 件のコメント
The iPhone is way better designed than this, when I had to replace my screen it was just two screws and the screen comes off first...
The iPhone is not IP68.
ignore him, he's a 12 year old iDiot who wants to feel better about his horrible purchase by spamming every samsung teardown with nonsense. probably gets bullied irl too
Lets not forget that this samsung device has a headphone jack.
Arnold -
Bogdan Lol sounds like a Samsung fanboy that has to resort to having to argue with people over the internet to get their way because they can't in real life. Also it isn't nonsense; its facts. The iPhone line has almost always had more repairability and durability because it has only 1 glass panel instead of 2. And, Steve's point is nonsense because it is only a difference of .5 of a meter and unless you plan to take your phone scuba diving it isn't very relevant.
@gigabit87898 Don't get worked up over this guy. Every device has ups and downs. iPhones can't have Qi because of the metal back. But Samsungs have glass which makes it prone to cracking. Samsungs aren't actually competing against Apple in the same way XBox isn't competing with PS4. Apple people will be Apple people and Android people will be Android people. Same deal with consoles. At least until they switch. And when they switch it likely isn't because of the repairability score.
Samsung isn't "The" Android anymore. If you really want to pit Android vs. apple it should be pixel vs. iPhone or not at all. Also take a look at the OnePlus 5's score.
@pccheese good point; I do have a Samsung and I don't really have a preference anymore when it comes to iOS vs android but I hate it when people bash apple with false facts.
well the note 4 was imo also better designed than this pile of crap, the battery could be replaced by the user without having to go through ANY screse and no %#*@ glue either.
My1 -
Really great tear down. You guys always go above and beyond. Looks like a nice phone, will be interesting to see what Apple responds with in a few days.
They are going to be innovative and add a 3.5mm stereo jack to their next model. Then charge $50 for some ridiculously sounding headphones.
The iPhone 7 is rated IP67. The difference between that and IP68 is undefined, up to the manufacturer, but immersion deeper than 1 metres, up to 3 metres.
In case anybody is wondering, "OIS" is an abbreviation for "Optical Image Stabilization".
IP68 is a defined rating. Basically 5 feet (1.5 meters) for half an hour with pressure shifts (can include phone and water movement). IP67 is 1 meter maximum pressure (device not moving, water still) for 30 minutes.
Do people even Google these days?
camera sensor name, please mention
Any idea where I can get that X-ray pic of the phone in Step 2 in full size?
Click on the thumbnail, then click on the image. It should take you to a new tab to show the full size image.
It is no longer about hardware. All of the top phones boast impressive hardware that is powerful enough for a majority of the cell phone using world. Now the battle has started shifting to software and in this aspect, I do think Apple has taken the lead with the focus on enabling normal people to take amazing photos. The latest announcement of the lighting toolbox on the new phones takes this even a step further. Augmented Reality is next up so it should be fun to see what the developers can come up with to entice regular people unto using AR.
I was an Apple user for a number of years (Iphone 5, 6 and 6S), I reluctanly moved back into Android with the Note 8.
The pics on my Note 8 look spot on mate! Especiall with the fantastic screen to view them on… I use a DLSR to so I can spot a sharp image or two…
What drove me away from Apple?
In order of annoyance, lack of built in memory, the screen size, ramping of pricing.
What I’ve found so far, is that Android apps are more prone to fall over, but the general connectivity provided by Google, leads to a more seamless user experiance and the screen man is AMAZING on the Note 8!
Hi. What model / supplier is the fingerprint sensor? Do you have any picture on that part?
Kevin Cass - 返信
Harder to disassemble means phone packs s lot of tech in a very compact way.
Lets remember that the today’s iPhone is a Samsung phone that you bought in 2014.
I hear certain countries actually let fanboys literally marry their devices. There's still hope. lol
Roger -
i second the OP!
Samsung really have a very good taste of style when it comes to tearing down iPhone is so crapy
Saying Samsung has a “good taste” when it comes to tearing down versus an iPhone could easily be sarcasm so I'm not sure what direction you're actually going in. I'm also not sure if you do repairs for a living or not but if you did you'd probably appreciate iPhones more than you seem to. lol
Roger -
Where is the LTE antenna located on these? After about a week suddenly my LTE signal went from about -80 dBA at home to bouncing between about -95 and -130 dBa. I still have my old Note 5 and on the same LTE band with the same carrier it sits pretty much right at -80 dBA in the same location…
This phone is very pricey. Could I save $$$ if I bought the parts independently and put the phone together myself?
Maybe you can buy all parts online but not now. Buy Galaxy Note 8 parts here.
Mandy -
Lord no lol. Samsung parts are kind of a pain to come by for some reason. They sell the phone as a full package for a reason.
The “I” phone may be easier to tear down but is that due to it neading to be easier due to the amount of times they need repairing, having all that glue prevents the components from moving about in relation to the other components, when a item is easy to pull apart that makes it much easier for components to shift and get damaged.
It’s not that easy to pull apart? It still takes a lot of force and parts are definitely screwed in so they don’t rattle around. Just the opening procedure is less intensive heating and prying and more unscrewing and suction cups. :P
We all have our choice of phones and tablets be it Samsung, Apple or Microsoft. iFix it isn’t the place to hammer at people for no reason really.
Lets face it every phone or tablet can break regardless of make. iFix it are here to help us all and that means regardless of which manufacture, we would be stuffed if they only stripped down just one manufacture be it Apple or Samsung.
So come on people stop arguing like kids in a playground and start accepting that we are all different in what we like.
if you are looking for the note8 spen. You can go to sfelectronics . biz and they give discounts to repair stores. Just leave a note at checkout that you are a repair store and get them for 21.99 each brand new
Im guessing its too much to ask ifixit to logically explain why the note 8 got lower repairability score than iphone 10 because if they honestly had to explain it, they would have to admit the note 8 is easier and WAY CHEAPER to repair than the iphone 10 but they are bias against Samsung’s superior smartphones.
The reasoning is laid out both in the teardowns and in the score steps. This phone loses two points for the lack of display accessibility and the increased difficulty of removing the battery. The iPhone X offers a display-first opening procedure, and has stretch-release tabs to ease battery replacement. Hope that helped!
Can anyone tell me what the yellowish sensor in the top right of the phone (see video at 59 seconds) with the water sensor on it is? It’s not part of the frame because it was removed at 1:41.
Its not a sensor, its yellow electrostatic tape and its holding down a pink tab of heat dissipation material
I have a broken screen that I want to replace it. I can’t tell whether I simply need a $24 Front Screen Glass or do I need the $200+ LCD Display Touch Screen Digitizer Assembly Replacement + Full set PreCut Adhesive? And if I only need the $24 Front Screen Glass, I haven’t seen anything about separating that from the front display.
The iris IC, where is it on the Note8 mainboard? Please hepl me find it! Thanks
It is S pen of note8, but two broke in 5 months. Looking at the cross section, the plastic inside is broken like metal fatigue. I think that it is because the stress was concentrated by the warp when holding the pen at the outer joint part. I would like you to see if it is a defective product that is easily broken down by breaking the pen. I would also like to ask if it needs to be disassembled if it breaks inside the case.
Where is the antenna cable located
Rick Moore - 返信
The note is not powering and it show hot sign when plug charger why can I do
Can anybody tell me what the little pink sticker is covering the gold wire in step 9 and if it does any damage if ripped???
Here I am in 2020 having just dropped my precious Note8 hoping that the glass replacement was simple… Alas the only two guides on ifixit involve specialist equipment…
Adam Frost - 返信
Not sure if you still check these or not anymore but I was just wondering.i'm going to be buying a screen replacement for a Note 8 just the outside glass. I seen a few pictures where it had a ribbon cable attached and a few pictures where it didn't have a ribbon cable attached. if I'm just replacing the glass on the outside should there be a ribbon cable on there to connect to the touch? Because I don't think you can transfer them over and I would imagine after removing it will be destroyed. Thank you
Kevin Cass - 返信
