はじめに
Use this guide to help you remove the broken or defected motherboard in your Sony Handycam HDR-Cx220.
必要な工具と部品
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
Use the plastic opening tool to release the front hook.
Use the plastic opening tool to release the back hook.
ある他の人がこのガイドを完成しました。
