メインコンテンツにスキップ
Sony Handycam HDR­-CX220 Display Screen Replacement
必要な工具と部品
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: 手順 1、 1の画像 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 2、 1の画像 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 手順 3、 3の画像 1 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 手順 3、 3の画像 2 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 手順 3、 3の画像 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 4、 3の画像 1 Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 4、 3の画像 2 Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 4、 3の画像 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 5、 1の画像 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: 手順 6、 2の画像 1 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: 手順 6、 2の画像 2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 8、 2の画像 1 Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 8、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 9、 3の画像 1 Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 9、 3の画像 2 Sony Handycam HDR­-CX220 Display Screen Replacement: 手順 9、 3の画像 3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Keven
メンバー登録日: 03/11/16
811 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016人のメンバー
UMASSD-BOTVIN-S16S8G5
3 メンバー
12のガイドは作成済み
3 件のコメント
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - 返信
gjhgvnvyh n hygfv
ANM WORLD - 返信
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 24
今までの合計 2,483
