はじめに
このガイドを使ってドックコネクタアセンブリを交換します。このアセンブリにはドックコネクタ、下部のマイクが含まれます。
必要な工具と部品
ロジックボードにドックコネクタケーブルのカバーを固定している次のネジを外します。
1.5 mmプラスネジー1本
1.2 mmプラスネジー1本
メタル製ドックコネクタケーブルカバーを外します。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
683 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
37 件のコメント
When I had changed the dock connector, my iPhone was not able to get a carrier signal. I found an helpful answer in the forum which worked perfectly for me. Make sure you set the correct date and time (after you remove the battery, it will most probably show you 1970) remove the sim card and plug it in again. That worked for me.
I bought the pro tech toolkit and liberation kit and set my work area to the longest one hour of my life. Everything inside the 4s is so tiny and fragile, I was in constant fear of breaking something, but the teardown videos and the comments on this page really help me to get through the entire process.
Thank you everybody and let us continue tinkering our way through all the adversities in this life! Peace!
This guide was perfect! Very detailed and explained everything very well. Only thing I found confusing was step 17, but besides that it went perfectly smooth!
