Charging Port / Micro USB
3件の回答 0 スコア |
headphone icon stuck in notification bar |
2件の回答 5 スコア |
3.5mm headphone jack is short-circuited |
2件の回答 2 スコア |
wifi and bluetooth issues. In Redmi Note 3 |
1 件の回答 0 スコア |
Why is my phone not switching on? MY PHONE IS CHARGING BUT NOT SWITCH |
ツール
以前、このデバイスの修理に使われていた一般的な工具です。修理過程において全部の工具が必要とは限りません。
Background and Identification
The Xiaomi Redmi Note 3 Android smartphone was produced by Xiaomi, Inc. and launched in March 2016. The Redmi Note 3 is the successor of the Redmi Note 2 and the predecessor of the Redmi Note 4. The Redmi Note 3 was released in gold, silver, and grey bodies.
The Redmi Note 3 includes a glass front and an aluminum back and frame. It has a 5.5-inch display and a 16-megapixel main camera. The phone also features a rear-mounted fingerprint sensor, and accelerometer, gyro, proximity, and compass sensors. The Redmi Note 3’s fingerprint sensor and main camera are located in the top center of the phone’s back cover. The Redmi Note 3 includes a 3.5 mm headphone jack.
The standard version of the Redmi Note 3 includes 16 GB of internal storage and 2 GB of RAM. The Special edition includes 32 GB of internal storage and 3 GB of RAM. Both variants feature a non-removable 4050 mAh battery with 10-Watt fast-charging. A non-removable battery is one whose adhesive is permanent, making repair and replacement difficult. The device supports two SIM cards or a SIM card and an expandable microSDHC card.
A CNET review praised the Redmi Note 3’s display and low price but were disappointed with the phone’s camera and lack of removable battery.
Technical Specifications
Models: 2015116, 2015161
Release date: March 2016
Body:
- Dimensions and Weight: 150 x 76 x 8.7 mm (5.91 x 2.99 x 0.34 in), 164 g (5.78 oz)
- Build: Glass front, aluminum back, aluminum frame
- SIM: Hybrid Dual SIM (Micro-SIM/Nano-SIM, dual stand-by)
Display:
- Type: IPS LCD capacitive touchscreen, 16M colors
- Size: 5.5 inches, 82.6 cm2 (~72.4% screen-to-body ratio)
- Resolution: 1080 x 1920 pixels, 16:9 ratio (~403 ppi density)
Platform:
- OS: Android 5.1.1 (Lollipop), upgradable to 6.0.1 (Marshmallow), MIUI 9.5
- Chipset: Qualcomm MSM8956 Snapdragon 650
- CPU: Hexa-core (4x1.4 GHz Cortex-A53 & 2x1.8 GHz Cortex-A72)
- GPU: Adreno 510
Memory:
- Card slot: microSDXC (uses shared SIM slot)
- Internal: 16GB 2GB RAM (Standard version), 32GB 3GB RAM (High/Special version)
- eMMC 4.5
Main Camera:
- Single: 16 MP, f/2.0, PDAF
- Features: Dual-LED dual-tone flash, HDR, panorama
- Video:1080p@30fps
Selfie Camera:
- Single: 5 MP, f/2.0
- Video: 1080p@30fps
Sound:
- Loudspeaker: Yes
- 3.5 mm jack: Yes
- 24-bit/192kHz audio
Communications:
- WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
- Bluetooth: 4.1, A2DP, LE
- GPS: Yes, with A-GPS, GLONASS, BDS
- NFC: Yes
- Radio: Stereo FM radio, recording
- USB: microUSB 2.0, USB On-The-Go
Features:
- Sensors: Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
Battery:
- Non-removable Li-Po 4050 mAh battery
- Charging: Charging 10W
Miscellaneous:
- Colors: Silver, Gray, Gold
- SAR: 0.49 W/kg (head) 0.50 W/kg (body)
- SAR EU: 0.56 W/kg (head)
