8 の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
モデル
20382
Background and Identification
The Toro Super Recycler model 20382 (Rev A) is a 21-inch gasoline-powered walk-behind lawnmower. It includes a 160 cubic centimeter Honda engine and is designed to be self-propelled so the user can walk behind it without exerting much force. The lawnmower includes a bagger to keep cuttings contained and a FLEX handle for reduced vibration. It can cut grass and weeds to heights between 1.25 and 4.25 inches tall.
The Toro 20382 model is advertised to never need an oil change; Toro states that simply adding more oil when the oil level is low will prevent the need for an oil change. This model can also fold and lock for easier storage by reducing its storage footprint by up to 70%. The folding feature also allows access to clean under the lawnmower’s deck and to service the blades. The lawnmower is also designed to adjust to the user’s walking speed up to 4.8 miles per hour using Toro’s Personal Pace Self-Propel System. The 20382 model features a Super Recycler Cutting System that allows the user to fertilize their lawn as they mow.
The Toro 20382 lawnmower includes a rust-proof aluminum deck. It operates with a Honda GCV air-cooled four-stroke 160 cc overhead camshaft (OHC). The engine has a net power output of 4.4 horsepower at 3600 revolutions per minute and produces 6.9 foot-pounds of net torque at 2500 revolutions per minute. Honda recommends using unleaded 86 octane or higher fuel for this engine. The engine can hold up to 0.98 quarts (0.93 liters) of fuel and up to 0.58 quarts (0.55 liters) of oil.
Technical Specifications
Dimensions:
- Assembled Depth (in.): 44.857 in
- Assembled Height (in.): 18.563 in
- Assembled Width (in.): 23.25 in
- Blade Length (in.): 21 in
- Cutting Width: 21 inches
- Front Wheel Size (in.): 8
- Mower Deck Width: 21 in
- Rear Wheel Size (in.): 8
Details:
- Assembly Required: Yes
- CA (CARB) Compliant: CARB Compliant
- Cutting Height Options: 7-position
- Cutting Options: Bag, Mulch, Side-Discharge
- Deck Material: Aluminum
- Deck Type: Fabricated
- Drive Type: Rear-wheel Drive
- Engine Displacement (cc): 160
- Engine Make: Honda
- Engine Torque (ft.-lb.): 0
- Features: Adjustable Cutting Height, Deck cleanout, Smart Stow
- Fuel Tank Capacity (gallons): .25
- Included: Engine oil, Wheels
- Lawn Mower Type: Self-Propelled Lawn Mower
- Maximum Cutting Height (in.): 4.25
- Minimum Cutting Height (in.): 1.25
- Mower Size Type: Standard
- Number of Blades: 1
- Number of Handlebar Positions: 3
- Oil Capacity (oz.): 20
- Power Type: Gas
- Product Weight (lb.): 85 lb
- Rear Wheel Height: Low Wheel
- Recommended Oil Type: SAE 30
- Recommended Terrain: Flat, Uneven
- Refurbished: No
- Size of Yard: 1/4 - 1/2 Acre
- Start Type: Pull Cord
- Walk-Behind Mower Type: Self Propelled
