2 の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
ドキュメント
モデル
AW-7020-8004
Background and Identification
This rotary floor cleaner is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment. For safety, the user of this rotary floor cleaner should always wear safety glasses, and follow any other safety guidelines that are given by the company.
The MiTM Rotary Floor Cleaner model AW-7020-8004 is a high-power floor scrubber, and is intended to be used on larger projects such as driveway, sidewalks, or decks. It uses the 20 inch diameter cleaning disk to scrub the floors as the operator walks behind the machine and guides it. Mechanized floor cleaners eliminate the need for manual floor scrubbing, which is both difficult and inexact. Rotary floor cleaners, however, will give a highly consistent cleaning, and pushing the machine along as it cleans is much easier than scrubbing the floor yourself.
This rotary floor cleaner is recognizable by the long, two-pronged handle for the operator to hold when the machine is in use, as the yellow Mi-T-M logo on the top of the disk.
Technical Specifications
- Assembled Depth: 70 in
- Assembled Height: 22 in
- Assembled Width: 22 in
- Weight: 18 lbs
- Operating Pressure: 1,000 to 4,000 PSI
- Maximum Flow: 4.0 GPM
- Maximum Temperature: 180°F
- Nozzles (2 per unit): 2502
- Diameter: 20 in
- Design: Walk-behind
